Dashboard removal
Dashboard removal
Postby Asimonsen » Mon Mar 22, 2010 10:21 am
im looking to swap a dash from an 84 ram 50 into an 86 mighty max so i can get rid of the ugly turd brown dash pannal.
i started on the ram because the mitsu is my DD so i didnt want to screw anything up yet, but somthing is biteing around where the radio was and i can't see any bolts or screws or such holding it there. i have everything removed already exept the tach cluster and the dash is loose but wont come out and i dont want to yank on it because it will probly break.
my chiltons manual is absolutly useless here so i fugured i would ask around for help
Asimonsen
Engine Size: 4d55
Re: Dashboard removal
Postby mikewarme » Thu Mar 25, 2010 6:39 am
Is your old turd brown dash any good? By the way....... I suggest you just use a cut-off wheel to remove it.
mikewarme
Engine Size: 2.3
Postby Asimonsen » Mon Apr 05, 2010 12:57 pm
not realy, it has cracks running every witch way and 2 huge ones, one above the wheel and one above the glove box. thanks for the tip though max that proved helpfull
Asimonsen
Engine Size: 4d55
Return to Dash, Guages, Clusters & Interior Lighting
