Tach Cluster
Tach Cluster
Postby wabbitsram50 » Sun Nov 21, 2010 5:03 am
How hard would it be to add a new dash with a tach on it to an 89? I found one @ a local junkyard for cheap. Just wanted to know if there were any mods required to put it in.
1998 Dodge Ram 1500 Conversion Van
1997 Dodge Neon Sport
2000 Dodge Grand Caravan Sport
1989 Dodge Ram 50 2.0
wabbitsram50
Engine Size: 2.0
Re: Tach Cluster
Postby Alan » Sun Nov 21, 2010 11:09 am
There is a post on this forum that will walk you through the process of installing the tach cluster in the dash. It is pretty straight forward. It will show you how to wire the tach to work if your wiring harness doesn't have the wire already. I'm not sure if the 89 model had the wiring in place or not. My 91 model did have the wiring in place. You will need the oil sending unit for a gauge instead of a light for the oil pressure gauge to work. If the truck your getting the cluster from has the engine in it, go ahead and get the oil sending unit off the engine. It is located right next to the oil filter. It has one wire running to it.
Alan
Engine Size: 2.4
Return to Dash, Guages, Clusters & Interior Lighting
