mightyram50.net • View topic - adding AC to my 86 M M
Postby Asimonsen » Mon Sep 27, 2010 7:03 pm
2.0 G63B wideblock perfectly stock down to the lack of a power steering pump.
how hard would it be to find a compressor also how hard would it be to find an original evaporator (if they exist) for a first gen MM
would new ductwork be required?
is there a new dash cover i have to find as well to make up for added switches and such?
if an original one cant be found has anyone done a custom a/c rig up in any of their trucks?
Asimonsen
Engine Size: 4d55
Return to AC & Climate Control Systems.
