A/C thermostat?????
A/C thermostat?????
Postby wrngwae » Fri Aug 07, 2009 3:33 am
Ok all i have recently got the correct A/C bracket and pump for my 4d55. and i tell ya its no fun to hunt down some of these parts. but it is a fresh rebuilt york ac compressor and btw it sounds cool. but back to my question. in the wiring diagram i have for A/C it shows a thermostatically controlled system. when i turn on the A/C it does what it is supposed to but it gets cold and i mean damn cold i put a them probe in the vent and the air comes out at 35deg. hell yea sound good dont it but,,,,,i dont think it should be that cold. am i putting excessive load on my compressor? is that thermostat in the wiring supposed to be in the vent and regulating the clutch assy to maintain a certain temp? i haven't "froze" up yet but i think it is a possibility. and input would be great. on the up side if i run a hose from the duct to my cold Coors light my mountains should stay blue :handgestures-thumbup: lol
edit,,,,, i did get my new fan resistor put in too and i have all 4 fan speeds now too so i really worry if i run the fan on low for freezing up and doing compressor damage.
or Chinese parts!!!!
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Re: A/C thermostat?????
Postby TurboMax » Fri Aug 07, 2009 12:14 pm
that's cold!
Make sure you didn't put too much refrigerant also.
Have you tried adjusting your AC/heater controls to see if the temps. change?
TurboMax
Engine Size: 2.6T
Postby wrngwae » Fri Aug 07, 2009 2:57 pm
the refrigerant is right i have converted the compressor to the 134a and its cooooold, im a refrigeration tech,granted it is for industrial refrigeration but ist all about the same,,,,sorta,,,,,long story. and yes the temperature does change with dash control from the blue/red control but the compressor still stays loaded??????? what is that thermo control for or what does it due and where in the heck is it????????? now i got a innercooler, oil cooler and a trans cooler all crammed in that grill but nothing is blocked so im not getting a high discharge pressure which also creates a lock up/freeze up?????? so that is why i think it is in the wiring controlled thermothingy lol.
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Postby 4doorciv » Fri Aug 07, 2009 3:10 pm
Should have a probe on the evaporator.
-Ryan-
4doorciv
Engine Size: 4g63
Postby wrngwae » Mon Aug 10, 2009 3:27 am
oh yea,,,, it looks like it is dash destruction time than,,,,no fun but it has to be done. lol
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Postby LethalEthan » Mon Aug 10, 2009 4:18 am
It's on the evap housing on the raider.
LethalEthan
Engine Size: 2.3L
Postby pennyman1 » Sun Aug 16, 2009 3:04 pm
If it has one the wiring comes out of the top of the evap box. Is your evap box open or closed in front under the glovebox; if open, you don't have a thermostat control on it, closed you do. My 80 D-50 has an adjustable stat, the 85 i had didn't. Hopes this helps
Postby wrngwae » Mon Aug 17, 2009 8:00 am
no sir it is open, i haven't had time to look real good for it but it has benn better since i started this thread,,,,,,,,,,of course it will,,,,,,,,,,after i started trying to fix it. that is how it always works
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Return to AC & Climate Control Systems.
