mightyram50.net • View topic - My 87 white mits build
A place to post a build thread for your 2nd Gen truck.
(1987-1996)
Forum rules
Re: My 87 white mits build
Postby 19BaggedMitsu92 » Mon Aug 02, 2010 11:50 am
yo DeWire, we need to get some of the pics from this past weekend posted up to, just a reminder
19BaggedMitsu92
Engine Size: 2.4
What year vehicle do you own?: 1994
Postby Johnboy72 » Tue Aug 03, 2010 2:27 pm
^^Agreed.
Johnboy72
Postby FordTruckMan » Sun Aug 15, 2010 7:19 am
Damn dude, your truck is coming along, Hope you dont mind me takin notes because there is not really a lot of info out there about baggin these trucks. I'm plannin on gettin mine to lay out on 20's but I will only be runnin 18's. So needless to say, I'm payin attention to your threads, any info is greatly appreciated.
Uploaded with ImageShack.us
Uploaded with ImageShack.us/img]Money Cant buy you happiness, but it sure as hell can buy you plenty of things to make you happy.
FordTruckMan
Engine Size: 2.4
Postby Johnboy72 » Sun Aug 15, 2010 9:33 am
And that's what it's all about! Learning from each other. Now if we can get the wanker back in the garage with camera.
Johnboy72
Postby laidoutmits » Sun Sep 26, 2010 11:38 am
All right back on this thread. Next in making every thing clear under the frame I went to the frame cross member under the drive-shaft. I started by taking a strate edge and goung frame rail to frame rail and marked front and back of this cross member then cut it off.
laidoutmits
Engine Size: 2.0
Postby laidoutmits » Sun Sep 26, 2010 11:48 am
Once I cut off what was neccesary I looked at what I had to see what I could use to weld back for structure and support. This is what I came up with.
and that was the shaving and reinforcing of that crossmeber. next I welded in the bottom plate (When I made the first frame to frame mark I added the thickness 3/16 to that mark and then cut so when I welded in the plate here it would still be level with the frame)
laidoutmits
Engine Size: 2.0
Postby laidoutmits » Sun Sep 26, 2010 11:49 am
laidoutmits
Engine Size: 2.0
Postby laidoutmits » Sun Sep 26, 2010 12:29 pm
So next I went to the ever cumbersom tranny crossmeber. I started by marking the initial bolt holes and mocking to that.
laidoutmits
Engine Size: 2.0
Postby laidoutmits » Sun Sep 26, 2010 12:33 pm
With the original having bolts goin up to the factory nuts and that wasn't goin to work for this, so I went with bolts welded in and cut the factory nuts off.
laidoutmits
Engine Size: 2.0
Postby laidoutmits » Sun Sep 26, 2010 1:02 pm
then I fabed up some new flush frame height mounts. started with a couple strips of 2" x3/16 and welded 3 strips together to get the plate I needed( to make both sides at once).
laidoutmits
Engine Size: 2.0
PreviousNext
Return to 2nd Generation
