[phpBB Debug] PHP Notice: in file /viewtopic.php on line 1052: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EDT/-4.0/DST' instead [phpBB Debug] PHP Notice: in file /viewtopic.php on line 1052: getdate() [function.getdate]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EDT/-4.0/DST' instead [phpBB Debug] PHP Notice: in file /includes/functions.php on line 4505: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3706) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 4507: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3706) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 4508: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3706) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 4509: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3706) mightyram50.net • View topic - My 87 white mits build
A site for Mitsubishi Mighty Max and Dodge Ram 50 Enthusiasts.
A place to post a build thread for your 2nd Gen truck. (1987-1996)
Forum rules
with that of the pocket being left and the spindle still being able to tuck an 18" I started making some cups to mount bags to but not knowing exactly what I needed I made some trim to fit universals.
next I tried to set the spindle at slammed height but I ran into a binding issue and had to pie cut the upper and just give a relief cut on the lower arms
and there you have it tuckin a 25 " diameter tire . (25" tire half of diameter is 12.5" plus 12" ground frame hieght and u got 24.5" then I added a 1/2" to get 25")
