mightyram50.net • View topic - 4g63 help
4g63 help
4g63 help
Postby oldskewld50 » Wed Oct 13, 2010 1:48 pm
Is it better or worse to start with a non turbo engine and turbo it?
Duct tape fixes everything
oldskewld50
Engine Size: 2.4
Re: 4g63 help
Postby camoit » Wed Oct 13, 2010 10:55 pm
If you want to do it right then you need to lower the compression. Start with a turbo engine, it will have all the nessary parts to start with.
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Re: 4g63 help
Postby LSR Mike » Fri Oct 22, 2010 1:00 pm
It is best to start with a Turbo Motor, less having to find/make things that fit. I will disagree that you MUST lower the compression ratio. You have to run high to very high Octane fuel to keep the Knock Monster at bay if you don't. I raised the CR on my N/A 4G64 to 10:1 when I added the turbo. Strictly Racing and 110 Octane Gas
LSR Mike
#847 F/BMMP
SCTA-BNI/ECTA
ECTA Record Holder/Bonneville Record Holder
LSR Mike
Engine Size: 2.4L
Re: 4g63 help
Postby Josh2g » Mon Oct 25, 2010 6:38 am
I know people who have turbod the non turbo 4g63 with no problems, all they did was swap ECUs.
Josh2g
Engine Size: 2.4L
Return to General Questions.
