mightyram50.net • View topic - broken cam bolt
broken cam bolt
broken cam bolt
Postby 92slammedmitsu » Wed Jan 19, 2011 5:48 pm
hey guys heres the deal I was pulling 2.4 motor recently and a the engine hoist chain I had attached to a bolt on the engine was caught behind the cam gear and it broke the bolt out of the front of the camshaft. So my question is ...Can I use another cam and rocker arms from another head I have ? if so what would I have to do to make it work?
92slammedmitsu
Engine Size: 2.4
Re: broken cam bolt
Postby pennyman1 » Fri Jan 21, 2011 6:47 pm
Have you tried taking a chisel and try to spin it out? The bolt should come right out as the torque on the bolt is only like 10lbs or so. A bolt for a 2.6 cam is the same.
pennyman1
Re: broken cam bolt
Postby 92slammedmitsu » Sun Jan 23, 2011 3:59 pm
Nevermind I found my answer thanks anyways
92slammedmitsu
Engine Size: 2.4
Return to Head & Block
