[phpBB Debug] PHP Notice: in file /viewtopic.php on line 1052: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EDT/-4.0/DST' instead [phpBB Debug] PHP Notice: in file /viewtopic.php on line 1052: getdate() [function.getdate]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EDT/-4.0/DST' instead [phpBB Debug] PHP Notice: in file /includes/functions.php on line 4505: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3706) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 4507: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3706) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 4508: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3706) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 4509: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3706) mightyram50.net • View topic - How to turbo mighty max????
A site for Mitsubishi Mighty Max and Dodge Ram 50 Enthusiasts.
Hi my name is Dave I am new to this site I have a 92 mighty max 2wd I was thinking about slapping a turbo on it I was wondering if anyone knows the tricks. I herd that you can put a 2g tsi head on the 2.4 bottom end is this true? If it is how do I wire in the sensors like the cas? Do I need to swap the motor harness?
Kerby you're slipping!!! Its at the top of the home page- hotrodcoffeeshop. Also look up the b2600 site- the mazda guys were hopping up the mitsu- supplied 2600s and there is a lot of good tech there as well.
Pennyman1 Living the D-50 life since 1980 The best Dodge that Dodge never made
