I Need Help!!
I Need Help!!
Postby pebbles » Thu Jan 07, 2010 1:31 pm
Hey guys...and girls...I dont get on here often. I am typically on maxd50scene.com. I asked a few questions on there and they haven't been answered. I have an 87 d50. I just moved to North Carolina and I left my truck in Oregon. I might need to go pickup it up and drive CROSS COUNTRY. lol. That's going to suck. Anyway....I lowered it by cutting the springs and it is such a bad ride. Slammed and needs a massive alignment and eats tires up like crazy.
My questions:
1) Where can I find some lowering springs for my DODGE RAM 50?
2) Would I have to use aftermarket shocks in order to use lowering springs?
Thanks ahead of time for the help....
pebbles
Engine Size: 4cyl
Re: I Need Help!!
Postby Spicoli » Thu Jan 07, 2010 5:04 pm
Summitracing.com sells lowering springs.
If you want the ride to be nice shocks are yes.
--keRby
Ad Inexplorata
Spicoli
Re: I Need Help!!
Postby LethalEthan » Fri Jan 08, 2010 6:56 pm
AIM industries also sells lowering springs I think, at least they used to. You could also go with drop spindles. Gauge magazine used to sell them on their site, AIM should also sell them. Lowering shocks will help out a TON with ride quality, but they are not required with either springs or spindles.
LethalEthan
Engine Size: 2.3L
Re: I Need Help!!
Postby pebbles » Fri Jan 08, 2010 8:16 pm
Alright thanks guys. So I cant find springs....I think I am going to go with spindles and drop shocks. Anybody know where I can get some good quality spindles?
pebbles
Engine Size: 4cyl
Re: I Need Help!!
Postby Spicoli » Fri Jan 08, 2010 8:21 pm
Only one place sells em, AIM. try airbagit.com
--keRby
Ad Inexplorata
Spicoli
Re: I Need Help!!
Postby pebbles » Fri Jan 08, 2010 11:33 pm
Thanks again guys. It really helped. So the drop spindles only give you 2" though righ? Anybody got any pics of this? I wana see how low I will be? And what kinda drop do the dop shocks give you?
pebbles
Engine Size: 4cyl
Re: I Need Help!!
Postby pennyman1 » Sat Jan 09, 2010 9:01 am
Dallas hot rods makes a set of upper and lower control arms for our trucks that give 1-2" of dorp and correct balljoint angles with screw it bjs. they are made for bags, but can be ordered for springs. He can also make them for more drop- these also eliminate the strut rod. There is some welding involved to accomidate the strut rod elim. Ask Johnboy about these- he installed the first set of these on his truck.
pennyman1
Re: I Need Help!!
Postby pennyman1 » Sat Jan 09, 2010 9:03 am
As for the drop shocks, they don't give you drop, they control the wheel movement by being valved for the range of motion that has changed by lowering.
pennyman1
Re: I Need Help!!
Postby pebbles » Sat Jan 09, 2010 9:44 am
Oh...ok..I see. Well I thought that drop shocks wouldn't give you drop but wanted to make sure. If I already cut the bump stops off would that have any effect on installing spindles? Would it still be a horrible ride or would the spindles surpass the bump stops.
pebbles
Engine Size: 4cyl
Return to Genral Questions.
