Another Junkyard SCORE!
Forum rules
Postby RusTy Max » Thu Jan 28, 2010 7:15 am
So I've been yardin' a lot lately and I got a major score this time. Got some intermittent wipers for $5!!! Also got a full stock center console out of a power ram for $5! Then picked up some PERFECT CONDITION sun-visors another... yep you guessed it, $5! I'll get some pictures up as soon as it's all installed!
RusTy Max
Engine Size: 2.4L
Re: Another Junkyard SCORE!
Postby netstat » Thu Jan 28, 2010 7:29 am
i want intermittant wipers ... anything more involved in switching than just swapping the switch/arm assembly?
if its just pull out the old one and put in the new one, then I am buying a set. (even tho they are like $100 new at napa ... thats how much i don't like not having intermittents
netstat
Engine Size: 2.4L
Postby Mojave Magic » Thu Jan 28, 2010 1:16 pm
I'd love to hear what's involved too. Trying to steer, shift, and mess with wipers is getting old.
1988 Power Ram 50 75k miles SOLD :(
1998 Ram 3500 quad cab SLT Laramie 5.9 12v Cummins
Mojave Magic
Engine Size: 2.6
Postby 85TDW50 » Thu Jan 28, 2010 3:08 pm
Mojave Magic wrote:I'd love to hear what's involved too. Trying to steer, shift, and mess with wipers is getting old.
From what i remember the (at least for the 1st Gen D50's anyway) Delayed/Intermitent Wiper equipped trucks have a Different Wiring Harness with an additional plug, Different Wiper Motor & the Wiper Stalk/Arm
You can run a 2-Speed Wiper Motor on a Truck that was equipped with Delayed Wipers (plug n play), but not vice versa, at least without tearing into the wiring harness and steering collumn. My '84 and '85 both had Delayed Wipers (Sport optioned trucks) But when i replaced the Cab on my '84 i never got around to reinstalling the original Wiper Motor (so i'm stuck with 2-Speeds), same thing with my '85. I need to do some digging in the other garage and find those motors.
The Delay/Intermitent Wiper Motor uses Two 4-Pin/Wire (8 wires total) Plugs, where the 2-Speed Wiper Motor just uses One 4-Pin/Wire Plug
84 Dodge Power-Ram 50 Turbo Diesel
92 Dodge Dakota 4x4
76 Dodge Ramcharger
74 Plymouth Duster 340
73 Dodge Dart Sport 340
72 Dodge Demon 340
71 Plymouth Duster 440
70 Plymouth Duster 340
65 Plymouth "Formula S" Cuda 273
85TDW50
Engine Size: 2.3L
Postby netstat » Thu Jan 28, 2010 3:33 pm
if they went through the trouble of plugging the clock harness into a blank plastic piece just to have the harness there wouldn't it stand to reason that the other 4 pin harness is lurking around in there too? I gotta take my column apart anyway to figure out why my ignition is bent down, i'll root around while i'm in there.
netstat
Engine Size: 2.4L
Postby 85TDW50 » Thu Jan 28, 2010 3:41 pm
Actually the 2nd Plug connects to the Wiper Motor itself.. If it's there it should be hanging right beside the Plug that's connected to the Motor now
92 Dodge Dakota 4x4
76 Dodge Ramcharger
72 Dodge Demon 340
85TDW50
Engine Size: 2.3L
Postby RusTy Max » Thu Jan 28, 2010 5:18 pm
Actually I took out the whole assembly, both the wiper arm side and the headlight side. All in one piece that goes around the steering column, (held in by two screws) and then unplugged the harness under the dash. Plugged in the new one, screwed in the new one, and tested it out. WORKED! It's really that simple... the only hard part was finding a truck that already had the intermittent wiper to take! I didn't do anything with the motor, all the intermittent arm does is regulate the voltage that goes to the motor. That's how it works.
RusTy Max
Engine Size: 2.4L
Postby 85TDW50 » Thu Jan 28, 2010 5:23 pm
They Must have changed the wiring layout between the 1st Gens & 2nd Gens. Cause the 1st Gens had different wiring harnesses for various options.
Like the plain old Power-Ram 50 Wiring Harness i pulled out of the Replacement Cab for my '85 Sport (Diesel) didnt have any plugs for the Center Console Gauges, Tach, Clock, ect.
But the spare Sport harness for my '84 (that i installed in the '85 cab) had plugs for everything
92 Dodge Dakota 4x4
76 Dodge Ramcharger
72 Dodge Demon 340
85TDW50
Engine Size: 2.3L
Postby RusTy Max » Thu Jan 28, 2010 5:25 pm
Gas Engine harnesses and Diesel Wiring harnesses are DIFFERENT.
RusTy Max
Engine Size: 2.4L
Postby 85TDW50 » Thu Jan 28, 2010 5:45 pm
That i know. what i'm saying is
Standard/Base Model (Gas) 1st Gen Wiring Harness had no plugs or extra wiring for Options
Sport Model (Gas) 1st Gen Wiring Harness had plugs & wiring for every option i could think of.
I just happened to use a spare Sport Model (Gas) Harness for my Diesel because it had plugs for the options (center console gauges, clock, ect)
92 Dodge Dakota 4x4
76 Dodge Ramcharger
72 Dodge Demon 340
85TDW50
Engine Size: 2.3L
Return to General Talk
