It started life as an '85 Power-Ram 50 2.3L TD, but needed ALOT of work. To the point that i think pretty much the only part that is original on the truck anymore is the Engine Block itself
At one point i actually considered dropping the engine in my '87 Power-Ram 50 (W50 as i call it) "Parts Truck" / Dumptruck,
Here was one of the first parts i hauled in, a Replacement Cab (took me ages to find one in this area)
Here's the "New" Cab sitting on the "New" Frame, and a set of 40" Mudders that i borrowed from my '76 Ramcharger
Setting the Bed off the '83 D50 Parts Truck on
Unfinished Front Bumper & Upper Plow Frame/Harness
Driver's side with the body work almost finished on the door, running 7.50-16's , with 2.25" cut out of the Front & Rear of the Fenders (to clear the 40" tires i had on before)
Some of the interior
The Engine, Hydroboost Conversion, and most of the Engine Compartment
Still need to install the Intercooler, and a few other parts. Also ditched the Alternator/Vacuum Pump combo for a 120amp Nippondenso Alternator & converted over to Hydroboost brakes.
