mightyram50.net • View topic - Steering question *New question added*
Stock Trucks.
Postby MightyG54BTMax » Sun Jan 24, 2010 4:57 pm
Anyone got a truck lying around with the steering gearbox out of it? My column has a lot of "slop" in the end that connects to the gear box and was wondering if thats normal when its unhooked from the gear box seeing as how its tilt wheel. Column is still bolted down.
Last edited by MightyG54BTMax on Wed Feb 03, 2010 4:57 pm, edited 1 time in total.
MightyG54BTMax
Engine Size: 2.6
Re: Steering question
Postby wrngwae » Mon Jan 25, 2010 5:20 am
try tightening your box first. it easy you need a 17mm wrench and a flat tip screwdriver if i remember correctly.now dont get too rammy or it will not want to return to center after a turn.
or Chinese parts!!!!
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Postby MightyG54BTMax » Tue Jan 26, 2010 4:36 pm
Im not talking about the steering box, im talking about the steering column itself. I can take the end inside the engine compartment and wiggle it around quite a bit.
MightyG54BTMax
Engine Size: 2.6
Postby Spicoli » Tue Jan 26, 2010 6:24 pm
Gimme till the weekend and if I remember Ill look for ya on one of the rigs Ive got torn apart.
--keRby
Ad Inexplorata
Spicoli
Postby wrngwae » Wed Jan 27, 2010 4:20 am
ah,,,,,,,,,,sorry about that. so is your slop in the slip joint or the universal joint part?
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Postby MightyG54BTMax » Wed Jan 27, 2010 2:43 pm
That i don't know. It seems to come from farther back then the rubber joint right there. If i jiggle it, it will clunk around.
MightyG54BTMax
Engine Size: 2.6
Postby wrngwae » Wed Jan 27, 2010 4:06 pm
hmmmmmmmm, under the dash? if so its steering column time.
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Postby MightyG54BTMax » Sun Jan 31, 2010 11:06 am
I think I figured it out. Seems to be missing the bushing and another part that I can't remember the name of on the end in the engine compartment. Time to order more parts from the dealer.
MightyG54BTMax
Engine Size: 2.6
Postby MightyG54BTMax » Wed Feb 03, 2010 4:57 pm
Instead of staring a new thread, I'm just going to ask it in the same one since its about steering as well. Anyone ever shortened a column before? Im putting the PS gearbox from my Starion in as the only ones I can find for the MM are 4x4 and they bolt to the other side of the frame. It bolts up to the stock location, but the shaft coming out of the box is longer which it turn puts the steering wheel farther back and into my fat ass. Im pretty sure this mother is a 1 piece so it shouldn't be hard at all. I'll probably do it the same way minitruckin did the drag link (cut the section out at an angle and weld with a sleeve). I might drill holes in the sleeve and fill with weld too.
MightyG54BTMax
Engine Size: 2.6
Re: Steering question *New question added*
Postby RusTy Max » Wed Feb 03, 2010 6:51 pm
I had the same problem... finding a PS gearbox on 'correct side' of the frame rail. But keep looking, you'll find it. It WILL NOT WORK, on the other side of the frame rail without changing out A LOT. Including the gearbox, steering rack, control arms, bushings, lines, ect. Just find one that fits on the correct side of the frame and save yourself a HUGE headache!
RusTy Max
Engine Size: 2.4L
Return to Stock Front & Rear Supension, Steering.
