i've got a 64 scout for instance did a chevy 350 with a th350 with the dana 20, its spring over with 2.5" lift springs, now runs on propane with 50 gals of it in the back,
i aquired an all original Arizona car 72 Firebird formula 400 with a 400 and a th400 with a 12bolt posi the interior is wasted which is a common AZ problem but body is of course cherry.(looks just like the rockford files firebird same color and the trunk rack)
Got a 67 Plymouth Belvedere with the original 318 with the 727 and only 85000 orig miles on it and its got an all new interior, owned it since i was 15 still never driven it
A 77 ford f100 with a bb 400 and c6 motor is built to the hilt and burns the tires in all gears with 2.75 rear gears, too much torque ripped the motor mounts out of it twice, and all that with a holley 500cfm 2bbl but thats ford's for ya, they like big cams and small carbs(lots of vacuum)
and couple other projects that arent done yet and one bad ass truck that i had got stolen and has never been and probanly never will be recovered
Just rambling but interested if some of you are just bolt on bandits or real builders/mechanics
