mightyram50.net • View topic - What did you do to your truck today?
Forum rules
Re: What did you do to your truck today?
Postby netstat » Mon Mar 01, 2010 1:28 pm
MightyMax wrote:those horns.. howd u get it to work correct again lol every single time ive messed with the steering wheel horn, it spells disaster
make sure the two clips are lined up at the top, slide the bottom in, tighten the set screw from the back.
netstat
Engine Size: 2.4L
Postby prospect » Mon Mar 01, 2010 1:40 pm
netstat wrote:
TotallyBalistic wrote:what happened to this fkn thread
I'll fix the thread. A day late tho since I didn't do anything today.
Yesterday I installed the intermittent wiper setup I bought from Rusty. Install process went something like this.
1) look at job and think "this aughta be easy"
2) remove horn button
3) remove 17mm retaining nut for steering wheel.
4) wiggle, wiggle, plull, pull, hit, smash myself in the face with the steering wheel.
5) throw steering wheel, check for blood
6) remove plastics from steering column
7) notice that the reason my ignition is out of place looking is the fact that it is actually out of place, both bolts backed them selves out about 1/4 of the way
8) remove old wiper arm assembly
9) remove ignition
10) use my dremel to make slots in the ignition bolts so I can tighten them back up with a screw driver
23) go back inside and play Borderlands
I did those exact same things, though I was going to take out my rear window when the steering wheel came off. My ignition did the same thing so I put a notch in the bolts too.....then borderlands >_>
prospect
Engine Size: 2.6
Postby wrngwae » Mon Mar 01, 2010 5:00 pm
i changed the oil,,,,,,,,,fresh filter now for annother 3g miles ya know i got over 91k on that raider now remember it had 66 when i got it.
or Chinese parts!!!!
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Postby fixerupper10 » Tue Mar 02, 2010 6:33 am
lets see...put the oil pan on. the water pump back on. all the other ods and ends back on. changed the brake shoes. got the battery charged up. hopefully will start later on. changed out the stock headlights for some cool new aftermarkets. then went and started workin on my maxima.
fixerupper10
Engine Size: 2.6
Postby TotallyBalistic » Tue Mar 02, 2010 4:38 pm
i didnt get to work on my macro today but i put 16!!! fruckin spark plugs in my dads 03 2500 with a hemi and brakes on the front of it, took 2 hours to do the whole thing
595
TotallyBalistic
Good Times
Good Times
Engine Size: 2.0
Postby natureboy » Wed Mar 03, 2010 10:52 pm
found a perfect tailgate for my truck with a bedliner protecto-thingy on it, $55! It's the metallic charcoal gray and my truck is the bright silver, but at least it's not red or tan!! Going back Monday for the front upper control arms/hubs/rotors from a 2g monty, since uncle Sam generously returned a healthy chunk of what he took from me last year. :evil:
natureboy
Engine Size: 2.6l
Postby fixerupper10 » Wed Mar 10, 2010 5:52 am
started the ram up after hours of charging the pretty much dead battery. found fluid goin everywhere that was green. first thought. engine coolant. found no leaks from engine coolant. looked on the ground some disgusting milky mixture that you get when you mix coolant and oil. found out that i put a hole about the size of a quarter and a crack about 7in. long. all because somehow one of the balance shaft screws was sticking out about a quarter of an inch. ugh now to take it all apart and send the damn thing off to welding.
fixerupper10
Engine Size: 2.6
Postby TotallyBalistic » Wed Mar 10, 2010 11:21 am
dang man that sucks...wish you well on that
595
TotallyBalistic
Good Times
Good Times
Engine Size: 2.0
Postby minimitz » Thu Mar 11, 2010 12:18 pm
ha i polished the ol rims up i forgot how nice they clean up lol
minimitz
Engine Size: 2.4
Postby moparducati » Thu Mar 11, 2010 6:32 pm
Tore my engine down, waitin for parts...
I hate not havin my truck to drive!
moparducati
Engine Size: 4d55
PreviousNext
Return to General Talk
