mightyram50.net • View topic - conquest leads
conquest leads
conquest leads
Postby paullen » Sun Mar 21, 2010 1:36 pm
Will 2.0 4G63T plug leads fit the 2.0 4G63 engine?
i'm struggling to find a decent set of leads for my truck, parts are thin on the ground over here. MAGNECOR do a set for the starion (conquest), but thats about all i cab find here.
paullen
Engine Size: 2000
Re: conquest leads
Postby paullen » Sun Mar 21, 2010 2:33 pm
Back to the drawing board.
Cheers.
paullen
Engine Size: 2000
Re: conquest leads
Postby 77amc » Mon Mar 22, 2010 6:00 am
You might be able to 'get by' with using a HIGH PERFORMANCE universal set for a V8.
Pull your old wire out from the piece that goes down in the head and tie some tooth floss around the new one and soap it up for lube and pull it on through to the desired length.
(DON'T use an oil base lube, it'll conduct electricity)
Cut to length at the cap and attach the boots..
I say V-8 because the sets are usually the same price as the 4cy ones and then you have two sets to use.
E
77amc
Engine Size: 2.6
