camoit wrote:Can some one send me a compleate copy of the site? including CSS style sheets. I'll make some changes then send them back for review. You can then send them to XAPHOS people for there aproval of the desine. I guess they ned to look at everything first befor you can drop it on there server. If I had a copy of there hole program and it shows how to set up the server side. I can test it on an old server i have laying in the garage. I would guess that it is a data base setup. If anybody can make use of a Netfinity 7100 I have one laying around. Of course Max get's the final say on everything.
Josh2g wrote:Just a suggestion but I think you guys should combine the 1st gen, 2nd gen and mighty max build topics because most of the trucks in the 1st & 2nd gen topics are Mighty Maxs anyways.
