mightyram50.net • View topic - tank hose
tank hose
Need a part? Post in here to see if someone has it.
Forum rules
All Wanted Item Are Automaticly Removed After 60 Days.
tank hose
Postby futat2 » Wed Aug 04, 2010 11:49 am
I have a 90 mm 2.4 and i need the hose that gose from the filler neck to the gas tank. im leaking fuel evrytime i fill up and need to fix it asap. i would like a new one but if you have a used one that is in good shape ill take it. if you got one let me now what you whant for it with shipping to VA 23518. thanks.
futat2
Engine Size: 2.4
Re: tank hose
Postby pennyman1 » Wed Aug 04, 2010 4:56 pm
See my response to the other post on the tank hose for what to use.
pennyman1
Re: tank hose
Postby D50DAVE » Wed Aug 04, 2010 5:07 pm
I replaced mine awhile back, it was only 30 or 40 bucks. I felt it was reasonable for a formed fuel hose.
D50DAVE
Re: tank hose
Postby mikewarme » Fri Aug 06, 2010 9:12 am
D50DAVE wrote:I replaced mine awhile back, it was only 30 or 40 bucks. I felt it was reasonable for a formed fuel hose.
That's the problem Dave. Most guys wont spend $10 to fix it right. Just order from oemmitsubishiparts.com
mikewarme
Engine Size: 2.3
Re: tank hose
Postby futat2 » Fri Aug 06, 2010 11:32 am
I will check there web site. thanks for the info.
futat2
Engine Size: 2.4
Re: tank hose
Postby mikewarme » Fri Aug 06, 2010 11:58 am
Call them ask for Keith tell him warmer sent you. He will give you part number
mikewarme
Engine Size: 2.3
Return to Wanted
