I just picked up a 87 toyota with a 4d55 . It came with no info from person who built it . The tranny which i assume to be the type thats in the ram 50 's because shifters look alike and configured the same . So whats The easiest way to get from the output shaft which is way driver side on the transfer case to the front . Should be looking to build a custome straight axle front end or would a ram 50 ifs setup already line up with this trasfer case . I could take pictures if needed . The head has 4d55 on it and it has a 5 speed tranny with a married transfer case .
