Results 1 to 25 of 43
Thread: Vacuum Diagram
    springtown, tx
    1989 Dodge D-50
    Vacuum Diagram
    Hello all,
    Does anyone know if there is a Vacuum Diagram on here for the 2nd Gen D50. I have a 89 and there are hoses that are plugged off on my truck. I have done oil change, new plugs, new spark plug wires, new rotor and new distributor cap. Truck does not run any better and runs like it is missing and it smokes out of tail pipe.
    Any suggestions..?
    Does this look correct?
    If it's smoking black out the pipe then you are getting to much fuel. The choke might be stuck closed. The float may have sunk.
    Direct link to images.
    http://www.mightyram50.net/camoit/smog/85-96-smog1.jpg
    http://www.mightyram50.net/camoit/smog/85-96-smog2.jpg
    springtown, tx
    1989 Dodge D-50
    Hello Camoit,
    Thanks for the diagrams. The smoke is white and the motor shakes like it is not firing right. It's not a cloud of smoke where you can't see through it, but as if it needs a tune up. I don't know what else to do. I know who ever had it last cut some wires and there are some vacuum lines plugged off.
    For instance, the wiring harness that goes to the alternator, has a thick wire that screws onto the alternator in the back. Then there is a Black plug that has 2 small wires in it that plugs to the back of the alternator. Then there is this yellow wire that is with the other wires, but it is cut and just laying there attached to nothing?? What a mess it is under this hood.
    springtown, tx
    1989 Dodge D-50
    Oh, forgot to mention, mine appears to be the 2.0 Liter
    Pretty sure the yellow wire to you speak of goes to the oil dummy light sensor on the bottom of the oil filter housing.
    Josh
    09 BMW 335i E92 Twin turbo
    White smoke and a bad shake? Oh that could be bad. Hows the water level? I'm thinking blown head gasket now.
    The 2.0 and 2.6 are the same mechanically and vacuum wise. As for the wires if you look in the manual and source info section> over 216 manuals> find the "haynes_Pickups_and_Monteros-1983-1993" manual. It has a full schematic in there.
    We can hope it's the EGR valve making it run rough buts let eliminate the gasket first. A stuck EGR valve can make it run like crap at an idle. But the bad head gasket will miss fire all the time.
    springtown, tx
    1989 Dodge D-50
    Camoit, I have had cars with blown head gaskets, but this one I'm not sure. I know the water level is fine and there is no chocolate coating in the oil. The white smoke is not thick, it's kinda light and it smells like emission problems. Like I said, there are vacuum hoses disconnect and plugged off?? I don't know what that person was thinking about or doing. The spark plugs are even inside of a adapter, why I don't know. lol
    springtown, tx
    1989 Dodge D-50
    Thanks for the reply. I will check that out!
    The adapters were used to try to resolve a fouling problem. If you live in a state where you don't need to worry about SMOG then I would put on a Weber and a header and get rid of the feed back carb. The cat may be plugged. Pull the EGR valve and clean it out. If it sticks open then it will run rough.
    springtown, tx
    1989 Dodge D-50
    Camoit, where is this EGR you are speaking of? Also, do you think it would make a difference if I took the adapters off? We don't have to go through emissions where I live.
    Portland, OR
    Not knowing what engine you have, or what the set up is on the 2nd Gens....gonna just flat guess and hope it's like mine. It should be on the front side (front of engine) of the intake manifold under the carb. Or at least close to it. Can be removed and blank-plated if you don't have to worry about emissions. Just one less thing to go wrong!
    springtown, tx
    1989 Dodge D-50
    I took 3 pictures of some of the issues I see under the hood.
    1 of the pictures, you see the Big Blue connect by the battery. On end the 2 wires are cut..not sure where they go. I tied them in and put them on the positive battery post. Not sure if that is correct or not.
    In another pictures, there is a black connector with 3 vacuum lines attached to it that have been plugged off with blue silicone. I am sure it went somewhere, but not sure.
    In the last picture, there is a vacuum line coming off the carb and it has been plugged off too! Not sure where that line is originally suppose to go.
    I have a book on order, but till then, if anyone knows where these things go, I would greatly appreciate the help.
    Thanks,
    All of the plugs by tye battery are supposed to be connected to the battery. The second pic under the first intake runner or around there there is a sensor that those three vaccum lines go to.
    Josh
    springtown, tx
    1989 Dodge D-50
    DroppedMitsu,
    Thanks for the assistance with the hoses. I put a new valve cover gasket on yesterday and it ran a little better. I unplugged the lines and put them in place, now it is running like it is missing again. I still have the smoke though. I don't know what to do. There is one more line that is plugged and it is the one coming off of the carburetor in the 3rd picture. Im not sure where it goes. Then under the carburetor pan, there is a empty nipple something goes there, not sure what line though.
    I don't think a blown head gasket would cause the exhaust smell and white smoke. I'm I wrong?? I had a Honda Civic that had a blown head gasket, there was no white smoke and no exhaust smell, only the white milky substance inside the valve cover and oil cap.
    springtown, tx
    1989 Dodge D-50
    Well, I found the EGR and took it off. Looks clogged up wonder what problems this would cause?
    this picture shows the lines that should connect to a TVS in the water jacket on the manifold. It would normally be with in reach of the lines. As for the EGR if it was stuck open. it will cause a vacuum leek and it will run like crap. Have you pulled the O2 sensor to see what it looks like? These feed back carbs are crap. If you don't have SMOG then I suggest swapping to a Weber. Also try plugging off the PCV valve hose. See how it runs then. Re torque all the intake bolts. Also if you have the box on the fender with 10,000 vacuum lines running in it. They like to crack in there. I'm still concerned about the white smoke being a head gasket. With the radiator full to the top and the cap off. If you start the truck does water shoot out like after a hard night of drinking? Or does it just sit there like a good dog? Also can you get us a overall picture of the engine area, so we can see if there is somthing we might be overlooking.
    springtown, tx
    1989 Dodge D-50
    Camoit,
    I did unplug the hose from the pvc and it smooth out pretty good. I cleaned the pvc and put it back and all was good. Hopefully cleaning this EGR will work. I just got a gasket for it as there wasn't one there. Look at the 3rd picture in my previous post. Can you tell me where that vacuum line off the top of the carb goes? My is plugged/capped off.
    Also, attached a full veiw of engine bay.
    Thanks
    springtown, tx
    1989 Dodge D-50
    Maybe this picture is better.
    I want to say that one curved right back to the carb it's self. I increased the size of the diagrams for you above.
    springtown, tx
    1989 Dodge D-50
    I did what you suggested. i started the truck with the radiator cap off and no water jumped out. i even added no smoke fluid in and let it idle for about 5mins and went back to check and it was smokey outside. i drained some of the fresh oil to make room for the no smoke fluid and the fresh oil had a gas smell to it like the old oil. is that normal?
    When you pull the plugs what do they look like?
    In the Wiki we have a page in there on reading spark plugs. The only way fuel can get in the oil is past the rings or if the fuel pump is leaking it in there or when you stop the truck it's sitting in the manifold. Have you replaced the O2 sensor? For some reason it must be running rich. But you say it's white smoke, correct?
    springtown, tx
    1989 Dodge D-50
    Yes, it is white smoke. I have not checked the plugs again, since I put in the new ones. I know the spark plugs that are in there are in some sort of adapters. I thought about removing them, but I figured they were there for a reason. I can pull them to see what they look like. What I'm I looking for?
    Pull them out, remove the adapters. If you look at them they can tell you how the engine is preforming. http://www.mightyram50.net/vbulletin...d+a+spark+plug It can give you a base line to work from. The adapters were used by someone to keep the plugs from fouling. But using them can keep you from seeing what is truly going on in the combustion chamber. Also while there out can you run a compression test on each cylinder. You might also want to get a vacuum gage and plug it in to manifold vacuum. This will check the valves. If the needle whips back and forth then you can have a valve going bad. You can also look through the UTI training manual in the manual section. Look for ignition and smog. Information in there will help you to see what we are looking for. It covers basic knowledge of cars and trucks diagnosis.
    springtown, tx
    1989 Dodge D-50
    I pulled the new plugs I put in and the are BLACK already!! It is like black carbon on the tips of the plugs!! These are new plugs. What is happening?
    If there black then it's just dumping fuel in there. The float may be sunk or there can be somthing in the needle and seat. When it's running do you see fuel just dribbling in through the carb? Somthing is causing it to dump in raw fuel.
