Results 26 to 50 of 62
Thread: 89 ram 50 4x4
  1. #26
    acworth ga
    I just looked and fuel is going to secondaty
  2. #27
    Buckingham,VA
    4G67
    Yep, and I hope that you can get your problem fixed
  3. #28
    re check your timing. 8 deg. base. If it pings then back it down. Does it feel like it's running out of gas?
    Find me on FaceBook
    http://mobilemillwright.com
  4. #29
    acworth ga
    I just did it and there is fuel going into second barrell
  5. #30
    Did you check the vacuum lines going from the carb into the box on the drivers side inner fender? they rot off or mice get in there and cause a huge vacuum leak. Also clean out the egr valve located below the carb on the front of the intake manifold.
  6. #31
    acworth ga
    ok, what else could it be?
  7. #32
    acworth ga
    Yeah, all vaccume lines look good, ill check egr and timing for sure
  8. #33
    acworth ga
    Could the cam be worn? The rockers tap a lil but it runs, idles starts fine
  9. #34
    acworth ga
    And camoit, not until you hit higher rpms for a extended time, it putters and im not sure if its starving or overloading
  10. #35
    acworth ga
    And only when you drive it, if its parked it revs fine with no,puttering
  11. #36
    Cali
    i think its choking it w/ too much fuel.. i wonder if its that "constant vacuum line" u said u pulled from somewhere else and plug it into the secondary cuz the one that was there initially u said didnt have vacuum.
  12. #37
    acworth ga
    well it doesnt hace vaccume, but like it doest pour fuel out of secon sexondary untill you hit thr throttle
  13. #38
    acworth ga
    What could stop the vaccume? Could it br a worn out cam?
  14. #39
    Cali
    its hard to tell w/out seeing it and tryin to diagnose it. did u check all the vacuum lines like others have suggested on here already?
  15. #40
    acworth ga
    Yeah, all of em look good, i just orded the weber carb, id like to keep the mikuni if I can
  16. #41
    Cali
    Quote Originally Posted by crock1990 View Post
    it probably just has to be tuned and tweaked a lil bit. about the weber, a lot of ppl put them on these trucks and since u already ordered one might as well install it.
  17. #42
    acworth ga
    Will it improve gas mileage/power?
  18. #43
    Cali
    well its new and an upgrade so i imagine it should, especially if tuned right.. but I've nvr ran weber so idk. search the forum and u'll see theres topics about those carbs in here.
  19. #44
    Vanessa, Ontario
    1989 Dodge Power Ram 50
    Have you installed a new fuel filter located between the cab and the box of the truck? A fuel filter that's getting clogged can cause lack of power and bogging when accelerating.
  20. #45
    acworth ga
    Yeah, all filters are new, and fresh tune up
  21. #46
    acworth ga
    Wgats that plate on drivees side of block under the intake? Its poueing oul?
  22. #47
    Thats a pressure relief hole on the fuel pump - it means the fuel pump blew out from excessive back pressure and it is pumping oil out of the head. That confirms the fuel pump was part of the problem - now time to replace it with an electric one.
  23. #48
    acworth ga
    I cant really tell where its leaking from, the whole sidw of the block is covered in oil, the plate has 2 bolts, and is abt 12 in long... What caused the bwck pressure and how do I do away with the mechanical one? & when I saw pouring its 3 quarts every 30 miles
  24. #49
    acworth ga
    And its more towards tge back of the block, closer to the firewal
  25. #50
    Vanessa, Ontario
    The plate with the 2 bolts is the silent shaft cover. If you have an oil leak there remove the cover and any gasket material that's stuck on. Clean the block and cover with brake cleaner or acetone to remove any oil residue. Install a new gasket using a light film of silicone gasket sealer on both sides.
