Results 1 to 25 of 46
Thread: rear end setup for autocross
    Killeen, TX
    1991 Mitsubishi Mighty Max
    hey i'm pretty new to this site and a couple years new to mighty max/d50's. i know very little about suspension in general, but here's what i have for you guys. i have a 91 MM, 2WD, 4g64 and i want to race it at my local autocross. i plan on doing a 6g72 swap in the future as well, so i'm wanting a beefy rear end with disc brakes. i dont really care if its with springs or leafs. i just want a good setup that can handle the 6g72's power and have great cornering ability.
    so there it is. what can yall tell me?
    Esparto CA
    1982 Dodge Power Ram 50
    I dont doubt that the stock rearend is stout enough to hold its own, people have done v8 swaps and still use thestock rearend.
    if you really want a stout axle with disc brakes, get a 2nd gen montero rear - they even come with an air locker on some models
    1993 Mitsubishi Mighty Max
    Quote Originally Posted by Turtlentz View Post
    I want to race it at my local autocros
    Just spend alot at the Belltech site. Get the lowering kit, shocks and anti-sway bars. Then stop at the Energy Suspension site and get the rest of the polyurethane bushings you need; rear leaf spring, front lower control arm and strut rod bushings.
    I knew daredevils and I ain't got nothin' against them, ........it's just they're all dead.
    Killeen, TX
    any specific year? or just any 2nd gen montero?
    and thank you Lon, those sites are awesome. i didnt think they made any aftermarket anything for the MM. and i've been looking for a long time too lol
    Killeen, TX
    is there a way to swap in rear disc brakes if i keep the stock rear end?
    Esparto CA
    there is always a way... lol
    Killeen, TX
    is there any way you could elaborate? lol
    or, get a Ford Explorer 8.8 rear end with the disc's and all I understand it's a easy swap. Details are on the site somewhere...
    For autocross I would definitely get rid of the leafs and do a 4 link setup with coilovers or something. The rear end should hold up fine, and you can convert to disc brakes, just takes some custom fab work. Bracket, new rear lines, and whichever rotor you decide works good. I will be building a rear disc conversion for these trucks, but bit won't be for a little while.
    Josh
    09 BMW 335i E92 Twin turbo
    los angeles
    hey guys i didn't really want to start a new thread but i'd say my questions are pretty related to this one. I plan on getting the doetsch nitro slammer shocks because i've read they outperform the belltech nitros. and also, the summit sport truck shocks are supposed to be rebranded doetsch shocks, except cheaper, sooooooo if anyone knows the part# for the doetsch for our mightyrams, we could get the summit ones by cross referencing w/ them i guess. (summit doesn't currently list their sport truck shocks as available for ours. it would be a saving of $40 so if we can't fig it out, no biggie.) and also if you guys had other opinions for lowered sport shocks. i would need some convincing if i was gonna drop the extra cash for the belltech street performers though.
    i also wanna pick up the belltech sway bar set and haven't been able to find any reviews on here and on other forums, people are just posting when they put em on their big trucks. i know they're going to be great, but if anyone had personal opinions that'd be pretty sweet. i already love how my truck handles w/ the beltech springs and block drop 2.5/4 . i'm just super interested in sport truck handling and ill keep an eye on this thread.
    Killeen, TX
    is there a bolt on kit to convert from leafs to coilovers? or do i just swap the stock shocks with coilovers and remove the leafs?
    Orlando, FL
    G64B
    I have the nitro drop 2 shocks on my truck with a 2.5/4 drop with 18 inch wheels and my truck handles and take corners just like my awd lancer, for the summit shocks,for the front s10 shock will fit, for the rear shocks for a nissan pickup from 87-03. what prices are you getting for the shocks,
    Killeen, TX
    i have a feeling i'm going to have to replace my A frames with ones set up for shocks and springs in order to do a coilover conversion
    Killeen, TX
    Quote Originally Posted by Rahtid View Post
    then again, i might just do what you did and get the nitro set and replace my leafs. (they're kind of old)
    los angeles
    thanks for the info Rahtid! doetsch nitro's are $45.44 each. the summit sport truck (which are supposed to be rebranded doetschs) go for $36.97.
    los angeles
    but dang, if you're feelin the nitro drop 2's that much, then i might as well go for those! decisions decisions...
    Orlando, FL
    G64B
    steen3rddensity No problem, I looked at getting doetsch(summit) shocks but I able the get all 4 nitro drop II for the price
    of the doetsch nitro's,
    Turtlentz you can try using s10 coilovers http://umiperformance.com/catalog/in...uir9gq7ul2u7i3
    http://www.summitracing.com/parts/HA...450C/?rtype=10
    the 1st gen s10s and our trucks use the same shock length, so if it bolts into an s10 _ it should work on our trucks. However, the valving is different, so get adjustable bounce/rebound shocks on the coilovers for fine tuning. also consider running negative camber when autocrossing - about 3 degrees negative to start
    Heber, UT
    4G63
    Do they make camber/castor plates for the mightyram? I had them on my mustang and they were awesome. I'm sure if they don't it wouldn't be extremely tough to make some from another model work.. Just be sure to change your camber when you're doing your daily driving otherwise you'll go through front tires faster than you go through rears.
    actually the mitsu trucks are one piece with 2 slots to drop in between the upper control arm shaft and the frame - those are fender shims. Unfortunately, that is what everyone sells now...
    Heber, UT
    4G63
    I camber/castor plate looks like this- http://www.cjponyparts.com/product.a...FRPl7AodpTEAYg
    It mounts to the top of your strut and makes it fully adjustable forward and backward for caster and side to side for camber. They're a very good mod if you're doing anything on a racetrack or just to get your camber back to normal after a big lowering job so you don't wear the insides of your tires down to the cords in a week ha
    Ahhh, those are much better. Thanks for the visual
    Orlando, FL
    G64B
    camber plates are for vehicles with macpherson strut suspension, they still sell the one piece spacers for the A arm suspension that these trucks use http://www.speedwaymotors.com/Alumin...cers,3532.html http://www.speedwaymotors.com/JOES-R...t-4,34039.html but the body shims are cheaper and easier to get.
