Results 1 to 3 of 3
Thread: Slow wipers
    Sacramento,CA
    1986 Dodge Ram 50
    Slow wipers
    My wipers are very slow on low or high which sucks in heavy rain, ant ideas, plus I would like to convert to intermittent, how hard would this be and what do I need?
    Easy fix. Take a 12 mm wrench and remove the wiper arm. Use panther pis AKA penetrating oil spray of some kind WD-40 like that. Spray it down inside the pivots. If that does not work remove the metal cover on the motor. Where it has the worm gear. The grease is hard as a rock. Clean and re lube.
    Find me on FaceBook
    http://mobilemillwright.com
    Fernley, NV 89408
    multi switches with intermittent can be found on some of the Dodge trucks like the XPS's . they a strait bolt on and plug in, no mods needed
