Results 1 to 4 of 4
Thread: Starion to 2nd Gen Mighty Max 2.6 Turbo Swap
    File located online and made available
    This is a PDF file compressed to ZIP file.
    Download File Here:
    Starion-to-2ndGenMM-2.6_turbo_swap.zip
    Starion/Conquest parts needed for swap:
    Complete motor
    Turbo w/ downpipe or pre-cat
    Intercooler (1986-89)
    Wire harness and ecu
    MAF w/ intake hose and air canister lid
    Ignition stuff (igniter, coil)
    Fuel pump
    Oil cooler w/ lines and bracket
    Motor mounts (engine brackets)
    Brake booster check valve
    Power steering pump bracket
    Upper radiator hose
    Heater hoses
    Fuel rail hose
    Other parts needed:
    MM/D50 2.6 alternator/AC compressor bracket (if keeping AC)
    AC idler pulley
    2.5” exhaust tubing for downpipe
    2.5” or larger exhaust
    Custom intercooler piping
    Electric cooling fans (Taurus fans work great)
    K&N 1gen DSM air filter
    Caldwell
    1985 Dodge Power Ram 50
    I see this was posted 5 yrs ago but maybe someone has an update. I have a 1985 power ram 50 4x4 2.6. I would like to put a Starion/conquest turbo eng. in. Would rather spend $$ on the turbo than rebuild the 2.6. Any comments or suggestions would be great
    Cataula , GA
    I think there is a need to update this wiki with a few clarifications about the donor parts and the best ways to adapt things. I'm currently doing the swap and plan to document as much as I can.
    miami, fl
    1991 Dodge D-50
    ton of info scattered about 4x4wire
    http://4x4wire.com/forums/ubbthreads...ION_Bible.html
