Results 1 to 4 of 4
Thread: Weird no start when warm
    Orlando , FL
    1996 Mitsubishi Mighty Max
    Truck will start up and run fine, I will go in to a store return 5 mins later and will not start, Wait 10 mins or so and starts right back up. Some times it seems like it also helps when I feather the gas on restart about 10mins also. Some times after is starts back up it will have a higher idle and or surging idle.
    I have replaced the following in the last month hoping to solve the problem
    Coil
    Plugs
    Cap
    Rotor
    Full pump
    I am stumped on this! Any ideals! Thanks in advance
    Bad fuel pump...... and don't say I just replaced it as they can be bad brand new. I have run into that with Fuel Pumps,Alt's, Water pumps and thermostats
    sheffield, vt
    1978 Dodge D-50
    please elaborate on "restart"...you turn the key & nothing, or you hear the starter, or it sputters? my first thought when reading your thread was insufficient grounding/poor ground contacts or positive starter connections.
    Orlando , FL
    It turns over and dose not sputter or act like it wants to start , It seems to me like it is a intermittent ignition problem but a bad ground I feel would give me problems on cold start and when driving
