Afpr?
I'm doing a 1g 4g63 swap into an 89 mighty max.
Does this truck have a return line to the tank, or do I have to install a return line for afpr?
there is a return line - it is the smaller one off of the fuel pump
if you're asking that kinda question.... why would you want an AFPR ?
Thanks pennyman.
Dash- I'm using a walbro 255 so I wasn't sure if the trucks engine had a return line or if I needed to run a new line from the afpr. So hopefully I can tie into the existing return.
I did. Kinda mad at myself for not making the fuel line off the rail longtime let me run the regulator on the fender.
