ok guys here goes:
1988 dodge ram50 sport 2.6l with a Weber 32/36 DGEV Electric Choke :
the factory carb was a piece of crap
after installing everything seemed to run great it was winter when it was installed
summer time came along temp started raising and the problems started so after reading on here that the manual gas pump may be causing to much pressure. so after some advise i picked up here i bought this:
at first it seemed to help then the temp really set in weather wise and i started getting run on pretty bad it seemed no matter how i adjusted the carb it still ran on. so it got to bothering me that i didn't know how much fuel pressure i was pushing into the carb so i bought this last week
got it in today ran out installed it and got a shock!!!!
according to the gauge there was no pressure
@ all i mean
none
needle did not move so i got to thinking maybe it was broke so i took the gauge shot some air threw it the needle jumped right up there like it was supposed to.
so now i,m @ a lose is the manual carb pushing less than a 1/2 pd of fuel ?
is that what is causing the run on?
what is my next move?
i have only had the truck up to 73 mph once for about a 1/4 mile
so where do i go from here?
is the gauge to much for this manual pump?
i really don't want to go with a elec pump if i can keep from it.
but if i do post some suggestion's on what kind of pump that will hold up to the weber carb.
