I have seen many references for installing a Montero Gen 2 UCA on the MM to gain lift when tweaking the Torsion bars. Question is, The OEM part number given for a Gen 2 differs MR124879/80 up to 94 and MR296095/96 for 95-up. But it is a bit confusing as the aftermarket shows the OEM UCA P/N's listed as fitting 92-00 Montero's AND 97-06 Sports. Is there a true dimensional difference or is this Mitsubishi just changing P/N's for the same part? Also will I need the knuckle assembly as well from the Montero's?
TIA,
Steve
