Results 1 to 3 of 3
Thread: clutch problem
    Rathdrum
    clutch problem
    Ok i'm going to get off my ass and take the trans back out and see what I did wrong with the new clutch I put in. I think I put it in backwards because there is no pressure on the pedal. there were no markings on the new clutch saying which sid goes which way so I had a 50/50 change of screwing up. Well here at 2Time Donnies shop it is what it is. lol In case I have another issue, dos anyone know which way the clutch goes in? Springs out towards trans or in towards flywheel? If I remember I'll take pics when I get it apart.
    Ca
    1993 Dodge Ram 50
    Here you go, point the spring side (thick side) toward the trans ...
    I would double check Your old parts against the new installed parts, as subtle differences
    can cause problems.
    Sadly , many vendors use the 'cookie cutter' 'one size fits all' application guide
    P.s. Lol, You are doing great !! keeping Your sense of humor IS sometimes the best tool!!
    Last edited by claych; 07-25-2019 at 06:12 PM. Reason: picture vanished.7/23 7/24. __ pic is up again__ PIC VANISHED AGAIN, pic is up again 7/25
    Ca
    1993 Dodge Ram 50
    ^^donthekawguy
    Just checking back to see if the pic had vanished for the 4'th time
    so far so good as of 07/25/2019
