Page 12 of 12 FirstFirst ... 2101112
Results 276 to 282 of 282
Thread: Not The First Time
  1. #276
    Welcome back boozehero ~ not a fun drive ? Wuzzit cuzza bad weather conditions or uncomfortable seat or ? So what's going on in Baton Rouge that got you to drive there ?
    Mr Nosey George
    Thank you boozehero for the update & answered questions; you deserve a good rest... Perhaps your truck was carrying a heavy load over them mountains, slowing it down..? Or slow down was caused by the changed transmission to the five speed (does a stock 5 speed truck have the same rear gear ratio as yours?) BIG exhaust can make BIG changes to an otherwise mostly stock engine; sometimes, the change is very negative because a smaller diameter tube has more scavenging affect... Much brake work was accomplished on your truck (right?) check em again for dragging..? Like geezer said, the air/fuel adjust & pitch perfect timing (initial timing, vacuum & centrifugal) need to be correct + good compression 'n valve timing... Assuming your truck is not having any miss condition; it's just low on power..? Maybe refer to the "Low on Power" FSM troubleshooting chart..? Heck, I dunno... Have you ever turned the engine over with just your hands on the fan belts..? I did when all four spark plugs were removed and we were installing a new front crankshaft seal ~ it spun fairly easy... Did you change wheel or tire sizes..?
    Well, enjoy the fix as much as possible & maybe we can learn something from your efforts...
    Most Respectfully,
    George
  2. #277
    Carson City, Nevada
    4G52
    Thanks for the notes Gents.
    The truck has excellent acceleration and runs like a Timex...
    Compression is excellent and all other systems a "go".
    I have a 3.91 rear gear, went from 14" to 16" wheels/tires, and 5 speed.
    I've mentioned that the truck will BURY the speedo easily and runs at 75 without a hitch... all day long.
    Towing another vehicle behind the truck over a distance was not easy, although the truck did it without issue.
    I don't have intentions of doing that anymore, at least with this truck.
    Upcoming improvements:
    Re upholster bench seat,
    install sound killer and new brown carpet,
    probably repair dash pad.
    Finish installing A/C
    Maybe add rear sway bar
  3. #278
    Quote Originally Posted by boozehero View Post
    Ah Ain't Life Grand
  4. #279
    Carson City, Nevada
    4G52
    Yes, sometimes ^^^
    But I have about 60 other projects needing attention.
    Life is short baby
  5. #280
    Carson City, Nevada
    4G52
    I've been in Seattle, Baton Rouge, New York and now Emmitsburg Maryland.
    All in the last 3 weeks.
    Heading back to Baton Rouge in the Wiener Truck (1987 Dodge Dakota - more later)
    The truck in this thread is sleeping in Baton Rouge, I'll be waking it up and back to service.
    More to come
  6. #281
    Hope Uncle Sam is paying a gas stipend allowance
  7. #282
    Carson City, Nevada
    4G52
    Been a while... I just bought a RARE intake for a 2.0 to mount 2 Weber 40 DCOE side draft carbs.
    The intake came from England and is on the way. I boght 2 knockoff carbs that are almost exact copies of the Webers.
    I'll post pix soon.
