Results 1 to 6 of 6
Thread: Bolt in seat rails
    Jacksonville Fl
    1992 Dodge Ram 50
    Bolt in seat rails
    Hello everyonr, i went to the junkyard to look for new seat rails and it was a great success. I took measurements of the stock seat rails and came across a 92 2600i mazda b series, the rails looked similar and they were pretty close in measurements so i took them. They practically bolt in theyre slightly shorter but 30mm bolts solved the issue theyre solid, that and adjusting the length of the wire to adjust the seat but besides those two things easy. Besides the seats i grabbed the cluster. Ill let you guys know how that goes.
    Jacksonville Fl
    1992 Dodge Ram 50
    Alright so no luck on the cluster no way would it fit without major rework. The seat was looking good, but the bumper on that bseries was very nice all chrome no rust either i had to have it, so i went back today and got it. also pretty much bolts on. One of the three holes lines up if you want them all bolted youll need to drill a couple holes. It looks a bit wonky i might have put it on wrong im gonna look at it monday.
    Jacksonville Fl
    1992 Dodge Ram 50
    Just saw someone already did the bseries seat swap. Thought i was onto something there for a sec
    ...all good. Just confirms the info is accurate
    Jacksonville Fl
    1992 Dodge Ram 50
    I checked the bumper today and it fits nicely. I had pallets on the truck and it made it look off. The bumper from a 2600i bseries bolts on
