Can someone tell me where i can buy seatbelt buckles for my 95 MM? ive looked everywhere i can't find anything. idc what color condition as long as it works passenger side.
You can buy complete retracting 3 point seatbelt and buckle assemblies new - cheap. Have a look on AliExpress. There are also different colour options and buckle designs as well. Prices are around $30ish USD.
Well that's one way to solve it...
Does anyone know of a seatbelt the would fit a first gen (86 mighty max) that is newer so it’s safer to have a child in it. Like one that locks up when pulled.
3 point seat belts are available new cheap. Swap both the seat belt and buckle so the clasps match. Start bargain hunting here -
https://www.aliexpress.com/wholesale...list.1000002.0
Do you know for sure if one of those will work? Looks like it’ll bolt in for the bottom bolt for the retractor part but will it fit behind the stock plastic cover?
They 'should' fit behind the trim cover, but when you are dealing with an obsolete truck that doesn't have a market you use what you can get
