Results 1 to 8 of 8
Thread: Interior dome light lens
    HERE IT IS FOLKS the LENS: from Amayama the part # is for a Starion trunk light but it's the same as a Gen1 truck interior dome light... Fixed my dome light today, works great...
    PHOTOS: http://www.mightyram50.net/vbulletin/album.php?albumid=674
    Online
    San Diego, CA
    1982 Dodge Power Ram 50
    Ordered this lens. Thanks so much.
    Online
    San Diego, CA
    Blast! They are sold out. :/
    You tried Amayama?
    Also try MEGAZIP & yoyopart.com
    At wrecking yards look in the rear of any Mitsubishi or Chrysler hatchback car that lens is used there too...
    Norway
    4G63
    Thanks for the info!
    Mine is still holding up somewhat, but it has a small crack in it.
    I've replaced the dead bulb with a 2400k LED bulb that looks exactly like an incandescent in the light output, so hopefully I won't have to disassemble the dome again, because I'm certain it won't survive it.
    I could maybe 3D print one if I take some measurements, but it won't look as good.
    However, I will be looking for one of these in the meantime.
    I rescued one of the last roadworthy 1st gen. in Norway in 2019.
    Trying my best to keep it alive and well!
    Thread
    Nice thread ostlar ~ electronics to pipe fitting & welding nothing stops you huh..! My favorites on your truck are the old style tie down hooks and the tailgate manual latches the rear window guard AND your mods too... The original alternator is 45amps and is it able to power all the sounds & lights..?
    Aloha from Hawaii
    Norway
    4G63
    Aloha from Hawaii
    Thank you so much for the kind words! And thank you for your contributions to this community, we appreciate it.
    Yes the original alternator does the job for daily tasks, but I can hear the belt squeak if all of lights are on, including all four original halogens.
    I've disconnected the inner high beam halogens to relieve some power
    Skål from Norway!
    Thread
    Online
    San Diego, CA
    Amayama actually accepted the order, but then told me they were out of stock and refunded my payment. I’ll try the others you suggest. Thanks.
