Hello,
Just ordered a 32/36 Carb after reading alot on these forums on how highly regarded they are, especially compared to the overengineered Mikinu. This will be my first time really modding a vehicle, I've only ever just replaced parts with stock, so venturing into this territory is a bit new for myself.
I had an inquiry. I am deleting the mechanical fuel pump and installing an electronic one. I'd like to replace the fuel filter considering the addition of the Webber and new pump. Just I am conflicted if the filter should go before or after the pump. If after, I could use the stock filter and just replace it, if before, I've seen a video use this filter, which I'd just rig before the pump. I've seen some use a filter before and after, but logically that doesn't make sense to me (if its filtered, its filtered, right?).
I also have some questions on EGR/emmissions, and vapor lock and how that works. But currently I'd just like to start with the basics.
Thank you
