Results 1 to 5 of 5
Thread: Water/coolant outlet housing part names
    Morro Bay
    Exclamation Water/coolant outlet housing part names
    Hello everyone,
    I have 1995 Mit Mighty Max 2.4L automatic, and I am racking my brain on what the part is called that has three sensors attached to it, (Red Arrow), that the thermostat is inserted into? I cannot find the part name of this. anything i reference says, "Thermostat Housing/Water Outlet". its the part that sandwiches the thermostat. Please help!
    For reference, Radiator > the upper radiator hose > thermostat housing > thermostat > What?(Red Arrow) > engine.
    I am trying to find this part to replace it
    On this picture it is labeled as number 7.
    Kent, WA
    I don’t think I can answer this, but anyway I don’t see a picture in your posting.
    tucson az
    4G61
    that is exactly what its called.... Thermostat Housing... if you need a replacement for yours.. you wont find a new one you need to get a used one.
    N*Y
    Kent, WA
    A couple years ago I bought a new part from O’Reilly for a 1989, 2.6 motor. It was called a thermostat housing/water outlet as stated above. Good luck.
