Results 1 to 6 of 6
Thread: 2.6L engine block question
    Lynchburg, VA
    Do all 2.6 blocks have a removable cover to access the balance shaft (intake side of the block)?
    Lynchburg, VA
    Where are all the experts?
    Earth - California
    Quote Originally Posted by dadsmax View Post
    I don't quite understand what you mean. You remove the timing cover and you get access to the balance shafts. The top right one and the bottom left one. Here is a picture of the balance shafts when timing cover is removed.
    Lynchburg, VA
    Cover on the side.
    there were 2 versions of the block - with and without the cover. I don't know why they are different - they take the same parts afaik. The blocks for the starquest turbo motors may not have the cover.
    Lynchburg, VA
    All the pictures I see online for Starions have the cover. Mine does not have a side access cover.
