Results 1 to 6 of 6
Thread: 6 wire harness to 7 wire maf help!
    Stockton ca
    I am trying to install 91 MAF on 90 mighty max. I have changed ecu already but i can not find the right way to connect the MAF.
    I have these colors for harness.
    Blk/red
    Grn/blue
    Pink
    Red
    Blk
    Blk/white
    I know i will have to add a wire for maf reset, and i know where it goes on the ecu pin from fighters post but i dont know where any of the wires go to on the maf. I do not have stock plug for MAF ether. HEEEEELP!
    Please.
    Pretty sure all the EFI components for the '90 are unique to that year only, not sure if a '91-up MAF even could be adapted to the '90-only system.
    Stockton ca
    I changed the computer also, finalfighter has a wiki about it but i dont have stock 91 maf pigtail to match the wire colors up too.
    redding ca
    ill take a picture of my 92 maf plug so you know what wires go where. The wire color scheme is the same on the 1990 and up but the 1990 uses a different style maf and plug but again the wire color scheme is the same. its just as simple as swapping ecm, adding the maf reset wire and and splicing in the new connector. This is assuming you have a connector from a 1991+ harness. i believe the 2g style maf plug from the 2g dsm's use a different color scheme. you can use the connector because its the same but will just need to match up the wires.
    Stockton ca
    Thank you final! i didnt want to be a bug and keep msging you.
    redding ca
    no worries, i work graveyard shift and i tend to be forgetfull.
