History & Background:Recalls-National Highway Traffic Safety Admin
National Highway Traffic Safety Administration
There are 2 listings available here to view.
I have place the Truck's recalls below in first because it pertains more to this Truck oriented forum.
Following this first Trucks listings is the entire list of NHTSA recalls for All Mitsubishi Vehicles.
TRUCKS LISTING
Most Recent Recalls for 1988 DODGE D50
Vehicle: 1988 DODGE D50
Component: POWER TRAIN: AUTOMATIC TRANSMISSION: GEAR POSITION INDICATION (PRNDL) Recall
1988 DODGE D50: POWER TRAIN: AUTOMATIC TRANSMISSION: GEAR POSITION INDICATION (PRNDL)
Manufacturer: CHRYSLER CORPORATION
Units affected: 3500
Report Date: 1987-12-26
Recall Number: 87V194000
Summary: AUTOMATIC TRANSMISSION MAY CONTAIN A PARK SPRAG ROD ASSEMBLY THAT MAY STICK IN THE TOOTH BUTT UNENGAGED POSITION.
Consequence: THIS CONDITION COULD ALLOW THE VEHICLE TO ROLL WITH THE GEAR SHIFT LEVER IN PARK POSITION.
Remedy: ALL INVOLVED VEHICLES WILL HAVE THE PARK SPRAG ROD ASSEMBLIES REPLACED.
Notes: SYSTEM: PARKING GEAR SHIFT VEHICLE DESCRIPTION: LIGHT TRUCKS AND VANS/WAGONS.
__________________________________________________ __________________
Most Recent Recalls for 1984-1985 DODGE RAM 50
Vehicle: 1984-1985 DODGE RAM 50
Component: ENGINE AND ENGINE COOLING: ENGINE Recall
1984-85 DODGE RAM 50: ENGINE AND ENGINE COOLING: ENGINE
Units affected: 6755
Report Date: 1984-12-07
Summary: THE ENGINE OIL PRESSURE SENDING UNIT MAY DEVELOP AN OIL LEAK.
Consequence: THE LEAK MAY LEAD TO AN ENGINE COMPARTMENT FIRE AND POSSIBLE PERSONAL INJURY.
Remedy: OIL PRESSURE SENDING UNIT WILL BE REPLACED WITH A MODIFIED TYPE FREE OF CHARGE.
Notes: IMMEDIATE REPAIR AN REPLACEMENT IS NECESSARY IN THE INTERESTS OF PASSENGER SAFETY.
Most Recent Recalls for 1986-1991 DODGE RAM 50
Vehicle: 1986-1991 DODGE RAM 50
Component: SEAT BELTS: FRONT: BUCKLE ASSEMBLY Recall
1986-91 DODGE RAM 50: SEAT BELTS: FRONT: BUCKLE ASSEMBLY
Units affected: 920000
Report Date: 1995-05-24
Summary: THE FRONT SAFETY BELT BUCKLE RELEASE BUTTONS CAN BREAK. THESE RED PLASTIC RELEASE BUTTONS ARE MARKED "PRESS." IF A BUTTON BREAKS, PIECES CAN FALL INTO THE BUCKLE ASSEMBLY CAUSING THE BUCKLE TO OPERATE IMPROPERLY.
Consequence: THE SAFETY BELTS WOULD NOT PROVIDE ADEQUATE PROTECTION TO AN OCCUPANT IN A VEHICLE CRASH.
Remedy: OWNERS SHOULD PROMPTLY CHECK THE CONDITION AND OPERATION OF BOTH FRONT SAFETY BELT BUCKLES AND CAREFULLY INSPECT THE RED RELEASE BUTTON FOR ANY BREAKS OR CRACKS. THEY SHOULD ENSURE THAT BOTH BUCKLES ARE OPERATING PROPERLY BY INSERTING EACH LATCH PLATE INTO ITS BUCKLE, TUGGING ON THE BELT TO MAKE SURE THE LATCH IS SECURELY LOCKED, AND THEN PRESSING THE RELEASE BUTTON. THE LATCH PLATE SHOULD POP OUT OF THE BUCKLE WHEN THE BUTTON IS PRESSED. IF EITHER RELEASE BUTTON SHOWS A SIGN OF BREAKING OR CRACKING OR IF EITHER BUCKLE FAILS TO OPERATE PROPERLY, OWNERS SHOULD PROMPTLY CONTACT THEIR AUTHORIZED DEALER TO SCHEDULE AN APPOINTMENT TO HAVE THE BUCKLE REPLACED OR REPAIRED, FREE OF CHARGE. THE MANUFACTURER IS DEVELOPING A REMEDY DESIGNED TO PREVENT FAILURE OF THE BUTTONS THAT ARE NOT CURRENTLY BROKEN.
Notes: SYSTEM: INTERIOR; SEAT BELTS; BELT BUCKLES. VEHICLE DESCRIPTION: PASSENGER, MULTI-PURPOSE VEHICLES AND LIGHT DUTY TRUCKS EQUIPPED WITH SAFETY BELTS MADE BY TAKATA CORPORATION. NOTE: IF YOUR VEHICLE IS PRESENTED TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND THE REMEDY IS NOT PROVIDED FREE OF CHARGE WITHIN A REASONABLE TIME, PLEASE CONTACT CHRYSLER AT 1-800-853-1403. ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-800-424-9393.
Most Recent Recalls for 1986-1991 MITSUBISHI MIGHTY MAX
Vehicle: 1986-1991 MITSUBISHI MIGHTY MAX
1986-1991 MITSUBISHI MIGHTY MAX: SEAT BELTS: FRONT: BUCKLE ASSEMBLY
Manufacturer: MITSUBISHI CORPORATION
Units affected: 658000
Actual Recall Stickers Placed Under the Hood of a 1986 Mitsubishi Mighty Max Vehicle that has been Serviced for a Recall in the State of California
TRUCK LISTING END
List Start for ALL 1983 to 2004 MITSUBISHI VEHICLES by NHTSA
NHTSA Recall ID: 95V103004
Mitsubishi CORDIA 1988 (88)
Mitsubishi Recall Campaign No.:
Component: SEAT BELTS:FRONT:BUCKLE ASSEMBLY
Recall Date (Y/M):1995/05
Defect: THE FRONT SAFETY BELT BUCKLE RELEASE BUTTONS CAN BREAK. THESE RED PLASTIC RELEASE BUTTONS ARE MARKED "PRESS." IF A BUTTON BREAKS, PIECES CAN FALL INTO THE BUCKLE ASSEMBLY CAUSING THE BUCKLE TO OPERATE IMPROPERLY.
Corrective Action: OWNERS SHOULD PROMPTLY CHECK THE CONDITION AND OPERATION OF BOTH FRONT SAFETY BELT BUCKLES AND CAREFULLY INSPECT THE RED RELEASE BUTTON FOR ANY BREAKS OR CRACKS. THEY SHOULD ENSURE THAT BOTH BUCKLES ARE OPERATING PROPERLY BY INSERTING EACH LATCH PLATE INTO ITS BUCKLE, TUGGING ON THE BELT TO MAKE SURE THE LATCH IS SECURELY LOCKED, AND THEN PRESSING THE RELEASE BUTTON. THE LATCH PLATE SHOULD POP OUT OF THE BUCKLE WHEN THE BUTTON IS PRESSED. IF EITHER RELEASE BUTTON SHOWS A SIGN OF BREAKING OR CRACKING OR IF EITHER BUCKLE FAILS TO OPERATE PROPERLY, OWNERS SHOULD PROMPTLY CONTACT THEIR AUTHORIZED DEALER TO SCHEDULE AN APPOINTMENT TO HAVE THE BUCKLE REPLACED OR REPAIRED, FREE OF CHARGE. THE MANUFACTURER IS DEVELOPING A REMEDY DESIGNED TO PREVENT FAILURE OF THE BUTTONS THAT ARE NOT CURRENTLY BROKEN.
Mitsubishi CORDIA 1987 (87)
Mitsubishi CORDIA 1986 (86)
NHTSA Recall ID: 83V057000
Mitsubishi CORDIA 1983 (83)
Component: VEHICLE SPEED CONTROL
Recall Date (Y/M):1983/06
Defect: SNAP PIN COULD INTERFERE WITH THE THROTTLE MECHANISM. IF THE ACCELERATOR PEDAL IS HEAVILY DEPRESSED, THE THROTTLE COULD BECOME STUCK IN THE OPEN POSITION. NORMALLY, WHEN ACCELERATOR PEDAL IS RELEASED, THROTTLE CLOSES AND VEHICLE SPEED DECREASES.
Consequence:
Corrective Action: METAL WILL BE REMOVED FROM THE CHOKE HOUSING COVER TO PROVIDE CLEARANCE FOR THE THROTTLE LEVER ASSEMBLY. IN ADDITION, THE CLEVIS SNAP PIN WILL BE REPOSITIONED AND A RECALL IDENTIFICATION STICKER WILL BE INSTALLED IF FOUND NECESSARY.
NHTSA Recall ID: 04V197000
Mitsubishi ENDEAVOR 2004 (04)
Component: TRAILER HITCHES
Recall Date (Y/M):2004/04
Defect: CERTAIN SPORT UTILITY VEHICLES MAY HAVE BEEN EQUIPPED WITH DEALER-INSTALLED TRAILER HITCH WIRING HARNESS AND CONTROL MODULE. THE ELECTRONIC CONTROL MODULE CAN OVERHEAT.
Consequence: OVERHEATING OF THE TRAILER HITCH WIRING HARNESS MODULE COULD RESULT IN A FIRE.
Corrective Action: OWNERS ARE BEING REQUESTED TO STOP USING THE HARNESS UNTIL A NEWLY DESIGNED REPLACEMENT IS PROVIDED AND CAN BE INSTALLED BY THE DEALER. OWNER NOTIFICATION IS EXPECTED TO BEGIN DURING MAY 2004. OWNERS SHOULD CONTACT MITSUBISHI AT 1-888-648-7820.
NHTSA Recall ID: 98V168000
Mitsubishi EXPO 1995 (95)
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Recall Date (Y/M):1998/07
Defect: VEHICLE DESCRIPTION: ALL WHEEL DRIVE PASSENGER VEHICLES. LOCKUP OF THE TRANSFER CASE CAN OCCUR DUE TO INSUFFICIENT LUBRICATION.
Consequence: THIS CONDITION CAN CAUSE A LOSS OF VEHICLE CONTROL, INCREASING THE RISK OF A CRASH.
Corrective Action: DEALERS WILL INSPECT THE VEHICLES FOR ADEQUACY OF THE TRANSFER CASE OIL VOLUME, TRANSFER CASE OIL LEAKAGE, AND OPERATIONAL DEGRADATION OF THE TRANSFER CASE MECHANISM. IF OIL VOLUME IS INSUFFICIENT, THE APPROPRIATE AMOUNT OF OIL WILL BE ADDED. IF THERE IS TRANSFER CASE OIL LEAKAGE, AFFECTED COMPONENTS WILL BE REPLACED. IF THE TRANSFER CASE SHOWS OPERATIONAL DEGRADATION, THE TRANSFER CASE WILL BE REPLACED.
Mitsubishi EXPO 1994 (94)
Mitsubishi EXPO 1993 (93)
NHTSA Recall ID: 97V063001
Component: LATCHES/LOCKS/LINKAGES:DOORS:LATCH
Recall Date (Y/M):1997/05
Defect: EXCESS LUBRICATION CAN CAUSE THE RUBBER DOOR LATCH SWITCH COVER TO DEFORM, AND THE DOOR LATCH SWITCH TO MALFUNCTION, SO THAT THE SHOULDER BELT ANCHORAGE WOULD REMAIN AT THE A-PILLAR WHEN THE DOOR WAS CLOSED.
Consequence: IN THE EVENT OF A CRASH, THE SEAT OCCUPANT MAY NOT BE PROPERLY RESTRAINED.
Corrective Action: DEALERS WILL REPLACE THE DOOR LATCH SWITCH.
Mitsubishi EXPO 1992 (92)
Mitsubishi EXPO LRV 1993 (93)
Mitsubishi EXPO LRV 1992 (92)
NHTSA Recall ID: 90V198000
Mitsubishi FE434 1990 (90)
Component: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:HOSES, LINES/PIPING, AND FITTINGS
Recall Date (Y/M):1990/12
Defect: ROUTING OF BRAKE VACUUM HOSE FROM THE VACUUM PUMP TO THE STEEL VACUUM PIPE COULD ALLOW THE HOSE TO BE PINCHED WHEN CAB ASSEMBLY IS RAISED OR LOWERED.
Consequence: THIS WOULD CAUSE AN INCREASE IN BRAKE PEDAL EFFORT, WHICHCOULD RESULT IN INCREASED STOPPING DISTANCE AND AN ACCIDENT.
Corrective Action: REPLACE BRAKE VACUUM HOSE WITH NEW-STYLE BRAKE VACUUM HOSE.
Mitsubishi FE434 1989 (89)
NHTSA Recall ID: 95V100000
Mitsubishi FE439 1995 (95)
Component: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL:CATALYTIC CONVERTOR
Defect: THE WELDED JOINTS CONNECTING THE CATALYTIC CONVERTER MUFFLER AND THE EXHAUST PIPE WAS INFERIOR. THE WELD CAN CRACK UNDER NORMAL OPERATION.
Consequence: THIS CONDITION COULD CAUSE EMISSION GAS LEAKAGE AND POSSIBLY COULD RESULT IN THE MUFFLER ASSEMBLY FALLING ONTO THE ROADWAY AND CAUSING A TRAFFIC ACCIDENT.
Corrective Action: DEALERS WILL REPLACE THE MUFFLER ASSEMBLY.
Mitsubishi FE439 1994 (94)
Mitsubishi FE444 1990 (90)
Mitsubishi FE444 1989 (89)
Mitsubishi FE449 1995 (95)
Mitsubishi FE449 1994 (94)
Mitsubishi FG434 1990 (90)
Mitsubishi FG434 1989 (89)
NHTSA Recall ID: 04V138000
Mitsubishi LANCER EVOLUTION 2003 (03)
Component: EQUIPMENT:OTHER:LABELS
Recall Date (Y/M):2004/03
Defect: ON CERTAIN PASSENGER VEHICLES SOLD IN THE UNITED STATES AND PUERTO RICO, THE GROSS VEHICLE WEIGHT RATING (GVWR) AND GROSS AXLE WEIGHT RATING (GAWR) AS STATED ON THE CERTIFICATION LABEL ARE IN ERROR.
Consequence:
Corrective Action: DEALERS WILL REPLACE THE LABEL. OWNER NOTIFICATION IS EXPECTED TO BEGIN DURING APRIL 2004. OWNERS SHOULD CONTACT MITSUBISHI AT 1-888-648-7820.
Mitsubishi MIGHTY MAX 1991 (91)
Mitsubishi MIGHTY MAX 1990 (90)
Mitsubishi MIGHTY MAX 1989 (89)
Mitsubishi MIGHTY MAX 1988 (88)
Mitsubishi MIGHTY MAX 1987 (87)
Mitsubishi MIGHTY MAX 1986 (86)
Mitsubishi SIGMA 1990 (90)
Mitsubishi SIGMA 1989 (89)
Mitsubishi SIGMA 1988 (88)
NHTSA Recall ID: 98V045001
Mitsubishi SPYDER 1998 (98)
Recall Date (Y/M):1998/03
Defect: VEHICLE DESCRIPTION: PASSENGER VEHICLES. THE DASH PANEL PAD CAN SHIFT INTERFERRING WITH THE THROTTLE CABLE CONTROL.
Consequence: THE THROTTLE CABLE CONTROL WOULD NOT RETURN TO IDLE INCREASING THE RISK OF A VEHICLE CRASH.
Corrective Action: DEALERS WILL REMOVE A PORTION OF THE DASH PANEL PAD SO IT CANNOT INTERFERE WITH THE THROTTLE CABLE CONTROL.
NHTSA Recall ID: 00V421001
Mitsubishi SPYDER 1996 (96)
Component: SUSPENSION:FRONT:CONTROL ARM:LOWER BALL JOINT
Recall Date (Y/M):2000/12
Defect: VEHICLE DESCRIPTION: PASSENGER VEHICLES. IF THE RUBBER BOOTS ON THE LOWER LATERAL ARM BALL JOINTS OF THE FRONT SUSPENSION WERE DAMAGED DURING ASSEMBLY, DIRT AND WATER CAN INTRUDE. ALSO, MMC HAS ADDED THE POTENTIAL OF LEAKING MOISTURE, WHICH CAN CAUSE THE BALL STUD TO CORRODE.
Consequence: THIS CONDITION COULD CAUSE THE LOWER LATERAL ARM BALL JOINT TO SEPARATE, INCREASING THE RISK OF A VEHICLE CRASH. THIS CAMPAIGN SUPERCEDES MMC'S PREVIOUS SAFETY RECALL CAMPAIGN, SEE 99V-066.
Corrective Action: DEALERS WILL INSPECT THE LOWER LATERAL ARM BALL JOINT FOR WEAR. BALL JOINTS THAT EXHIBIT WEAR BEYOND THE ESTABLISHED TOLERANCE WILL BE REPLACED WITH NEWLY DESIGNED LATERAL ARM BALL JOINTS. BALL JOINTS THAT ARE WITHIN THE ESTABLISHED TOLERANCE WILL BE CLEANED AND A SPECIAL SEALANT WILL BE APPLIED TO PREVENT INTRUSION OF MOISTURE.
NHTSA Recall ID: 99V066001
Recall Date (Y/M):1999/04
Corrective Action: DEALERS WILL INSPECT THE RUBBER BOOTS, AND IF THE BOOT IS DAMAGED, THEY WILL REPLACE THE LOWER LATERAL ARM AND BALL JOINT ON THE AFFECTED VEHICLES.
Mitsubishi STARION 1986 (86)
Mitsubishi TREDIA 1983 (83)
Consequence:
NHTSA Recall ID: 82V109000
Component: FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY:FILLER PIPE AND CAP
Recall Date (Y/M):1982/11
Defect: ON SOME OF THE INVOLVED VEHICLES, THE FUEL FILLER HOSE MAY BREAK IN A REAR-END COLLISION. THE FAILURE OF THE HOSE AND RESULTING FUEL LEAKAGE IS NOT IN COMPLIANCE WITH FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 301, "FUEL SYSTEM INTEGRITY".
Consequence:
Corrective Action: THE DEALER WILL INSTALL A FUEL FILTER HOSE PROTECTOR ON THE FUEL FILLER HOSE TO PREVENT FUEL LEAKAGE AT NO CHARGE TO OWNER.
Mitsubishi VAN 1990 (90)
Mitsubishi VAN 1989 (89)
Mitsubishi VAN 1988 (88)
Mitsubishi VAN 1987 (87)
Created by , 03-26-2013 at 11:07 PM
0 Comments, 4,645 Views
