mightyram50.net • View topic - free starion
free starion
free starion
Postby harrychronikjr » Sun Dec 27, 2009 5:01 pm
so a starion fan friend of mine, has given me a 89 with a bunch of crash damage. The interior is perfect, he is the 2nd owner. It has 89k on the clock and want to pull the 2.6 and trans for a swap. I fantasized about figuring a way to swap the rear end out too, but I don't think I have the skills for that to come out the way I would like.
So any links to useful info on the swap would be help full, also, has anyone seen a starion dash and console in a 2nd gen MM?
harrychronikjr
Re: free starion
Postby joey_crandall » Wed Dec 30, 2009 1:49 am
go to starquestclub.com. alot of helpful people there i also have a starion, want to buy it?
always gift wrap your package.
joey_crandall
Engine Size: SQ
Re: free starion
Postby marlin3030hntr » Sat Feb 13, 2010 4:17 pm
its a little more complex than just putting mounts and bolting it in you gotta make sure ur alignment is right and all tht or itll be dog tracking like a mofo. other than tht type of stuff its not all that complicared..... :roll:
-80 Arrow Truck(daily driver)
-64 Scout SOA conversion w/ chevy v8 and th350 swap(4x4 hunting rig)
-77 f100 w/ 400m(ass haulin pickup)
-67 Plymouth Belvedere orig. 318(8 yr project car and going)
-86 Mustang GT(weekend cruiser)
marlin3030hntr
Engine Size: 2.0
Re: free starion
Postby pennyman1 » Sat Feb 13, 2010 4:40 pm
I looked at that swap myself - to get it to fit the wheel wells requires you to narrow the whole assembly - way out of my skill range. the swing arm alignment requires a new arm to work properly. Or, using a set of dually style fenders to cover the wheels.
pennyman1
Re: free starion
Postby fixerupper10 » Tue Mar 30, 2010 4:54 am
actually it would be that easy to just swap in a new rear end. all you gotta do is take a tape measure and measure the left front hub to the left rear hub then do the same for the right and make sure the numbers are the same. thats what i did with my cousin on his swap. hell you can do a whole friking alignment on any car with a tape measure. you just gotta know what to do.
fixerupper10
Engine Size: 2.6
Re: free starion
Postby joey_crandall » Fri Apr 30, 2010 10:13 am
use the narrow bady rear control arms and a 4wd bedsides im sure it will fit.
joey_crandall
Engine Size: SQ
Return to Questions That Don't Fit Anywhere
