Hub removal
Hub removal
Postby Josh2g » Sat Oct 30, 2010 7:15 am
Ok this thing is a PITA someone help me out, how do I get the front hub off, what am I doing wrong? Are the 6 bolts in the hub suppose to come out? They turn forever but dont come out. The Haynes manual says you need a special socket to remove a "locknut" but I don't see it, is this true on 2wds?
Josh2g
Engine Size: 2.4L
Re: Hub removal
Postby TurboMax » Sat Oct 30, 2010 7:50 pm
To remove the hub you need to remove the big nut under the dust cap in the center of the hub. The six bolts hold the brake rotor to the hub. There are nuts behind the rotor thats why its spinning.
TurboMax
Engine Size: 2.6T
Re: Hub removal
Postby Josh2g » Sun Oct 31, 2010 3:54 pm
I finally got that bastard off today someone put an extra lock washer behind the bearing so there was 2 of them. If anyone else can't pull their hub off its because some asshole probably set you up for failure like they did me.
Josh2g
Engine Size: 2.4L
Re: Hub removal
Postby camoit » Tue Nov 02, 2010 9:44 am
Well at least showed it who is boss. And you found out the fastest way to get answers. IE chat board.
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Return to Genral Questions.
Users browsing this forum: No registered users and 8 guests
