Trans splines?
Trans splines?
Postby Might93 » Thu Jun 18, 2009 3:36 pm
Hey guys I have tried to search and cant find a thing. How many splines are on the 2.4 Might Max 5 speed tranny? I need to buy a clutch/pressure plate setup for the truck. My friend gave me his act pressure plate/clutch out of his 7 bolt eclipse but the pressure plate wont fit the flywheel. The clutch wont slide onto the tranny shaft either.
1994 Mighty Max, 4G64 block, 4G63 head. HKS cams, Wiseco Pistons, Eagle H Beam rods, .63 t3 turbo, ACT HD Clutch. Dropped 2"
Might93
Donator
Donator
Re: Trans splines?
Postby DroppedMitsu » Thu Jun 18, 2009 6:26 pm
23 spline
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Re: Trans splines?
Postby Might93 » Fri Jun 19, 2009 8:23 am
So whats the next step in getting a clutch setup? Heavy duty 2.4 or can I fit a 7 bolt 63 flywheel on it.
Might93
Donator
Donator
Re: Trans splines?
Postby Spicoli » Fri Jun 19, 2009 5:05 pm
On mightyd50 there was a lil formula for the good set up. PM 4g63mightymax he otta know it
--keRby
Ad Inexplorata
Spicoli
Re: Trans splines?
Postby Might93 » Sat Jun 20, 2009 8:04 am
I was under the impression mightyd50.com is down for the count
Might93
Donator
Donator
Re: Trans splines?
Postby RusTy Max » Sat Jun 20, 2009 2:05 pm
You can PM him here... he's a member!
RusTy Max
Engine Size: 2.4L
Return to Transmission.
