Vacuum Diagram????
Vacuum Diagram????
Postby kegster » Tue Sep 28, 2010 10:56 am
Hey, brand new to this site. Just bought back my first truck which is a 1988 Dodge Ram 50 2.6L 4x4 for $500. Thrilled to have the truck back. Anyways, the truck had a rough idle when I bought it and the drive-shaft center support bearing was messed up. Replaced the bearing and now working on the idle. Carb was dirty and there a few missing vacuum hoses. In the process of cleaning everything I removed the carb and found that the vacuum line going to the brake booster line was split at the base. Replaced the line but I don't have the carb back on yet.
Question is, does anyone have a vacuum diagram for these trucks? The Haynes repair manual is not to clear on this and there is no diagram under the hood.
kegster
Engine Size: 2.6L
Re: Vacuum Diagram????
Postby Boomer » Mon Nov 08, 2010 6:14 am
did you ever find a diagram?
Boomer
Engine Size: 2.0
Return to SMOG & Vacuum
Users browsing this forum: No registered users and 13 guests
