glow plug relay
Re: glow plug relay
Postby mikewarme » Mon Nov 15, 2010 8:44 pm
It wont have one Spencer. It will be KT.......... the glow controller controls your relays and everything glow plug related
mikewarme
Engine Size: 2.3
Re: glow plug relay
Postby 4D55 Performance Inc » Mon Nov 15, 2010 10:41 pm
mikewarme wrote:It wont have one Spencer. It will be KT.......... the glow controller controls your relays and everything glow plug related
It should have an MD part number in ink. All 4 of my glow controllers have a stamped KT and an inked MD part number.
Engine Size: 4D55
Re: glow plug relay
Postby sassafrass » Wed Nov 17, 2010 9:23 am
spence,
mine acts somewhat similar, but only under certain conditions.
the circuit board # K331B088
the case says K8T75176
and also 3310
i will call the rebuilders to see what they say...
tom
sassafrass
Engine Size: 2.3
Re: glow plug relay
Postby sassafrass » Wed Nov 17, 2010 10:37 am
spence,
i called the place you listed. $195 if they can rebuild it, 18month warranty. $15 to return to you if not rebuild-able. he seemed to have no idea what generally goes wrong with these, no factory support (they can't put in a new board). he will just have to bench test components to find out what is wrong, and R&R as necessary.
i am guessing that the #K8T... is the part number and the 4 digit number is a serial number. the reason i ask is i found a used one with a different 4 digit number.
tom
sassafrass
Engine Size: 2.3
Re: glow plug relay
Postby T-Bone » Sat Nov 20, 2010 4:25 pm
MD112305
T-Bone
Engine Size: 2.3l
Re: glow plug relay
Postby mikewarme » Sat Nov 20, 2010 6:32 pm
Wow I have 2 of those boxes and neither have the MD112305 number on them. I just know the number by design and from the book
mikewarme
Engine Size: 2.3
Re: glow plug relay
Postby T-Bone » Sun Nov 21, 2010 5:54 pm
The part number is md112305. looks like it is going to be around $400 from rock auto. might have to wait on it. Unplug it and the glow plugs don't work at all. I guess I could just bypass it for now.
T-Bone
Engine Size: 2.3l
Re: glow plug relay
Postby T-Bone » Tue Dec 28, 2010 6:28 pm
So I sent the ECU off to the Mitsubishi computer repair shop and they said that it was fine. Except that the contacts under the two little black boxes needed to be cleaned, which he did, and then sent it back. I plugged it in though and it still fires in quick successions after about 5 minutes of warming up. It actually seems like it might be worse. Also, after the initial 5 seconds of the 12v glow plugs, I can hear the computer shut them off and then the truck starts smoking until the truck warms up. In colder weather like the 40's is this smoking normal or should the computer fire 6v to the plugs which it does not seem to be doing? Thanks for any help
T-Bone
Engine Size: 2.3l
Previous
Return to Glow Plug and Hard Starting.
