mightyram50.net • View topic - Radiator
Radiator
Re: Radiator
Postby LSR Mike » Sun Nov 21, 2010 8:29 am
First posting has the dimensions drawing it was made from.
I got it thru Buschur Racing.
http://www.buschurracing.com/index.html.
LSR Mike
#847 F/BMMP
SCTA-BNI/ECTA
ECTA Record Holder/Bonneville Record Holder
LSR Mike
Engine Size: 2.4L
Re: Radiator
Postby LSR Mike » Sun Nov 21, 2010 2:27 pm
The drawing with the dimensions it was built to is in the first post. Some have already downloaded it.
Buschur Racing will hook you up with a unit.
http://highboostforum.com/forum/showthr ... w-Radiator.
Fluidyne will not deal with you direct for this, read their FAQ page.
http://www.fluidyne.com/tc_faq.html
I completed (well, I need some new hose clamps) the install today.
Here it is with the bits and pieces added. I used JB Weld to stick the fan mounting bolts to the upper and lower tanks.
Here's the final installation.
Drivers Side.
Passenger Side.
Anybody need a Stock Radiator? Fan with Clutch? Shroud?
LSR Mike
#847 F/BMMP
SCTA-BNI/ECTA
LSR Mike
Engine Size: 2.4L
Re: Radiator
Postby TurboMax » Sun Nov 21, 2010 4:52 pm
For stock trucks, you can use a radiator from a Montero as a bolt-on upgrade over the stock radiator. Core is thicker.
TurboMax
Engine Size: 2.6T
Re: Radiator
Postby Rahtid » Sun Jan 23, 2011 9:50 am
looks like the 3 core radiator on the 88 2.6 heavy duty or 1 ton truck
Rahtid
Engine Size: 2.4
Previous
Return to Cooling System Mods.
