Narrow block?
Narrow block?
Postby ipods.rocks » Tue Dec 28, 2010 9:50 pm
so, i found a rebuilt engiene for my truck, and i was wondering if a narrow block would fit into my 88 2.6 truck (manual transmission) i was wondering if everything would line up right
ipods.rocks
Engine Size: 2.6
Re: Narrow block?
Postby 4doorciv » Tue Dec 28, 2010 9:52 pm
Im sorry but I believe the 2.6 is a wide block. There was a thread on here somewhere with the measurements between the lower two belhousing bolts.
-Ryan-
4doorciv
Engine Size: 4g63
Re: Narrow block?
Postby ipods.rocks » Tue Dec 28, 2010 10:21 pm
yeah, i diddnt use the search function (im a idiot) is there any way of getting around this? also, is there any way to be positive that mine is a wide block?
ipods.rocks
Engine Size: 2.6
Re: Narrow block?
Postby 4doorciv » Tue Dec 28, 2010 10:51 pm
Well, I'm sure the 2.6 is a wideblock. You could get a km132 5 speed trans and it should bolt up to your exhisting driveline. If not then maybe a different motor is what you should be looking for. Also, I don't think your head would bolt up. Not deffinet but I'm sure.
-Ryan-
4doorciv
Engine Size: 4g63
Re: Narrow block?
Postby ipods.rocks » Tue Dec 28, 2010 10:56 pm
ok, so hypothetcally if i were to get a tranny that works with the 2.0 narrow block, i could get it into my truck and hook up all the existing wires and whatnot (like other than the tranny, it would work?
ipods.rocks
Engine Size: 2.6
Re: Narrow block?
Postby 4doorciv » Wed Dec 29, 2010 7:40 pm
I would think so. I wonder where the 2.6 guys are with their wisdom.
-Ryan-
4doorciv
Engine Size: 4g63
Re: Narrow block?
Postby wrngwae » Wed Dec 29, 2010 8:12 pm
2.6 wide block....if you go to a narrow block you need a new trans. stay with the wide block the trans are stronger and that aint saying much since they are not all that. ok. cool
or Chinese parts!!!!
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Re: Narrow block?
Postby 4doorciv » Wed Dec 29, 2010 8:33 pm
Someone with experience with the wideblocks. Also gives you a chance at a 2.6 starion turbo swap. ;) you got the trans already. Just a thought if sticking with the wideblock.
-Ryan-
4doorciv
Engine Size: 4g63
Re: Narrow block?
Postby DroppedMitsu » Thu Dec 30, 2010 9:23 am
You'll need the exhaust manifold for the 2.0 also. Goin through the 2.0 and 2.6 engines and bays in my head can't really think of anything else that wasn't said
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Re: Narrow block?
Postby capev86 » Thu Dec 30, 2010 4:25 pm
mitsu fwd cars.....4g63 2.0 and 4g64 2.4 are narrow block
truck g52b 2.0 with rwd & 5spd is narrow block
g54b 2.6 in early 80's dodge k cars is narrow block
truck g54b 2.6 and 4g63 2.4 are wide block
fwd engine block will bolt in place of a narrow 2.0 using the correct engine mounts. but plumbing is different and the dohc cyl heads require creative thinking to put in a longitudinal setup.
capev86
Engine Size: 2.0
Return to General Questions.
Users browsing this forum: No registered users and 15 guests
