mightyram50.net • View topic - Engine Sizes??????
Engine Sizes??????
Engine Sizes??????
Postby camoit » Sun Jan 16, 2011 3:06 pm
Simple question for some one out there.
#1 What engine sizes did the D-50 and the Mighty max come with?
#2 What engine model types did they put in them?
I need a complete list. From gas to diesel. Including all the engines that people are putting in them now.
I need this info to build on the Nrw member sign up page. I get people putting 1.8L 2.4L 3.6L and so on. I know there is no 1.8 unless you drive a Hibird.
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Re: Engine Sizes??????
Postby pennyman1 » Sun Jan 16, 2011 5:11 pm
Gas - 1.6, 2.0 g52b and g63b, 2.6 g54b, 3.0 6g72 . Diesel - 2.3 4d55 and 4d56 these are stock. swaps include 4g63 and 4g63t, 4g64, 6g74, and 302 ford, 350 chevy, small block mopar among others. All stock motors except the 1.6 and 2.0 g52B, were available in both 2wd and 4wd. 3.0 6g72 was an 87 up 4wd only as far as I know.
pennyman1
Postby camoit » Sun Jan 16, 2011 5:24 pm
pennyman1 wrote:Gas - 1.6, 2.0 g52b and g63b, 2.6 g54b, 3.0 6g72 . Diesel - 2.3 4d55 and 4d56 these are stock. swaps include 4g63 and 4g63t, 4g64, 6g74, and 302 ford, 350 chevy, small block mopar among others. All stock motors except the 1.6 and 2.0 g52B, were available in both 2wd and 4wd. 3.0 6g72 was an 87 up 4wd only as far as I know.
OK now is that D-50 ONLY? Or does that include the MM Trucks?
camoit
Admin
Admin
Engine Size: 2.6L
Postby pennyman1 » Tue Jan 18, 2011 6:25 pm
Both D-50 and MM, although the 1.6 and g52b are pre 83 motors, so they were not in MM trucks
pennyman1
Postby reddevillhs17 » Tue Jan 25, 2011 6:47 pm
are you talking just 1st gen or all together? cause if its all years, the 2.4 4g64 is a stock engine from 90 up
reddevillhs17
Engine Size: 2.4
Postby pennyman1 » Wed Jan 26, 2011 5:09 pm
Good catch - forgot that one. I must be slippen.... :o :oops: :?:
pennyman1
Postby camoit » Wed Feb 23, 2011 9:04 pm
Thank you for the information. I'm putting it to use in the new site Meta words, and key words. Thank you.
Do you think this covers what we want search engines to look for.
<meta name="keywords" content="Mitsubishi, Miighty Max, Raider, Montero, Dodge, Ram, D50, Power Ram, Mitsubishi Articles, Dodge Articles, 4 cilinder, V6, 2.0L, 2.6L, 2.3L, 2.4L, 3.0L, g52b, g63b, g54b, 6g72, 4d55, 4d55T, 4d56, 4G52,4g63, 4g63t, 4g64, 6g72, 6g72 V6, 6g74, 302 ford, 350 chevy, 4.3L chevy, turbodiesel, conversion, 4WD, 4x4, offroad, off-road, off, road, motorsports, racing, desert, trucks, race,turbo, Turbo Diesel, Diesel, baja, accessories, axle, hub, lift, suspension, air bag, bagging, draggin, transmission, engine, electrical, fuel, injection, ignition, electrical, gears, lockers, tires, 4.3L, efi, Emc, swap">
camoit
Admin
Admin
Engine Size: 2.6L
Return to General Questions.
