mightyram50.net • View topic - Help please. Rearend on blazer tore to hell
Forum rules
Re: Help please. Rearend on blazer tore to hell
Postby In2Deep » Fri Jan 14, 2011 9:40 am
Thanks merrit. I'm on my way down there now so I'll see what I can find
-Mikey-
In2Deep
Postby Merritt » Fri Jan 14, 2011 9:54 am
No problem man. Forgot to mention that any rear out of a s10 will work also, they're the same. If you ever need any help s10forum.com has a ton of info.
Merritt
Engine Size: 2.4L
Postby pennyman1 » Fri Jan 14, 2011 6:50 pm
The center section is, but the axle is 5" wider.
pennyman1
Postby Merritt » Sat Jan 15, 2011 12:31 pm
Really? I didn't know that. Scratch the s10 axle then.
Merritt
Engine Size: 2.4L
Postby In2Deep » Sun Jan 16, 2011 8:03 pm
got one out of a 93. couldnt find any with disc brakes. gonna put it in tomorrow when i get off work. do they all use the same kind of lubricant or will i need to check and see what it takes
-Mikey-
In2Deep
Postby Merritt » Mon Jan 17, 2011 12:04 pm
I would just go with a good 80w90 gear oil
Merritt
Engine Size: 2.4L
Postby In2Deep » Tue Jan 18, 2011 8:02 pm
So it turns out the one I bot was out of a 4x4 blazer. I didn't realize it was. And it is also 5 inches wider. Didn't realize that until I already cleaned it up and painted over the markings they put on it. I got the warranty so they told me to go talk to the manager of the yard tomorrow and he should work something out with me. So I'm hoping they won't be stupid about it.
-Mikey-
In2Deep
Postby In2Deep » Wed Jan 19, 2011 8:21 pm
So went back today. Got the right one this time. Kinda hard fittin it in the back of a bagged mighty max with everything in the bed. But I got it in and bolted up and drained. Everything seems fine. I'll put the the lubricant in it tomorrow after work. Then all that's left is new shoes and hook the e-brake back up and bleed the brakes. And hopefully I'll be good to go.
-Mikey-
In2Deep
Postby Merritt » Wed Jan 19, 2011 10:36 pm
Did the new one you got end up having drums too?
Merritt
Engine Size: 2.4L
Postby In2Deep » Thu Jan 20, 2011 7:32 am
Yeah they did. There was one rearend down there with disc brakes but it was in terrible shape
-Mikey-
In2Deep
Previous
Return to General Talk
