mightyram50.net • View topic - carb Help
carb Help
carb Help
Postby NCKidd16 » Wed Mar 09, 2011 12:38 pm
I have a holley 5200 on my g54b, i talked to holley and they said they no longer make those jets anymore, it says liscensed by weber in the float bowl, i was wondering if anyone knows if the weber jets will work in it, it has a lean bog to it and gets horrible mpgs, any help is appreciated, thanks
88 Ram 50 4wd, Rebuilt G54b 08/10, 30x9.50 bfg a/t,
NCKidd16
Engine Size: 2.6
Re: carb Help
Postby pennyman1 » Fri Mar 11, 2011 6:36 am
If the jets are no longer available, you could drill them out, but it is a one shot deal. Try ebay; it can be a great source for obsolete parts or maybe whole carbs for spare jets to drill out. Also you could try the junkyards for 80's mopar front drivers with 2.2 motors - thy ran that carb from the factory.
pennyman1
Re: carb Help
Postby NCKidd16 » Sat Mar 12, 2011 8:42 pm
Thanks, i may have to do that, i drilled out the secondary main jet, but its still a touch lean, im scared to try it again, if i do buy a geniune weber 32/36 does anybody have any suggestions on jet sizes?
NCKidd16
Engine Size: 2.6
Re: carb Help
Postby camoit » Sat Mar 12, 2011 8:58 pm
I thought nearly all holey jets are interchangable. You can always call my machine shop and ask them. They might have what you are looking for.
Rex Hutchison Racing Engines
916-483-9563
4526 Auburn Blvd
Sacramento, CA 95841
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Return to Fuel System Mods.
