I plan on dropping a 350 in my Max. Its a 95. I was wondering if the stock mounts will at all be usable. Able to be modified to use etc. Or would I be better off building new myself and starting from scratch. Is it possible to incorporate stock mounts- (frame side)- ones that are connected to frame/cross member ...in the swap or easier to make new.
If they are useable I would modify to fit. I am asking because I don't have the mock up block handy yet.
Thanks
