kxracer987 wrote:Alright, WTFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF. I tested it, and it came up normal.Atleast I think it did, a bunch of short sweeps, held it till I hit like 17, all the same, and all really short. There is no way a fuel filter would clog when it sat for no more than 5 minutes. What else could it be??
If you disconnected the battery the codes will be erased. The truck has to run to trigger a code again. I believe the ecu will have constant short sweeps till the o2 sensor heats up, then there should be constant voltage.
